How to hotrod Pro-jection
Discussion in 'The Garage' started by JeffHK5, Mar 27, 2005.
  1. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    I Have a Holley 2D 670cfm digital Pro-jection kit that is rated at 280 hp in stock form. Can you upgrade the two 80lb./hr injectors to something larger ? Is there any way to "tweek" this system for more HP's.
    Thanks Jeff
  2. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    pm Sandman he has done this. I tweaked mine by increasing the fuel pressure but it will only help a little.
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Is it the standalone system?
    If its not the standalone.... the stock computer with the projection tbi will support 275 hp with NO computer tuning and when you bump the pressure and get a prominator on there that number jumps to around 350-400hp in some of the thirdgen members camaroes.
    I don't know about the limit on the standalone but i would bet a prominator would have the same effect along with more psi.
    I am still waiting to get my prominator and am running a big pump with the holley tbi and manifold on my 88 k5... just did a swap and when its all said and done it will be in the neighborhood of 350 hp.
  4. rockjeep44
    rockjeep44 Newbie
    Apr 12, 2007
    Tennessee
    Bump...found this thread in a search. I'm building a 425+ hp AMC 401 and would like to reuse my Projection 2Di setup but I'm doubting if it can support those numbers. Is there anyone out there pushing those kinds of numbers with the 2Di kit or know of any mods to make it support over 400hp? Thanks
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Marv Springer has a Holley Kit on his 454 BBC. It ran strong in his buggy with aluminum heads & some other stuff. I don't know what his actual power numbers were but I know that motor was pretty stout. He may have some info on the Holley setup. I think that motor was capable of 450 HP but I don't know if the Holley limited that below that number because of fuel & airflow.
    I know he toyed with the idea or running a dual carb manifold and running 2 seperate Holley Projection setups at the same time on the same motor to get the upper RPM HP's from it. He is currently freshening up that motor for a new project that will be around 600 HP but he is going to use the Holley Commander 950 system on it. I have seen that system on a 496 BBC that had some nasty power in it.
    Harley
