How to Id a 205 and 208 t-case
Discussion in 'The Garage' started by odoa3, Jul 27, 2004.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I am trying to find pic's of a 205 and 208 t-case. Anyone know of any sites that have pic's or can tell you what to look for?
    Thanks for the help.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Most t-cases have the # on the rear of the case on a little circle piece of metal and it says what it is right in the middle of that piece.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    208 and 241's are aluminum , and the 205 is cast and looks like
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Best guess- what would a 75 K5 have for a transfer case? It is an hour away so I can't really go look. I found some info. that says I have a 203- but I can put it in 2wd. It has Warn Premium Hubs in it so perhaps I am just unlocking the front end? I would have sworn it has a 208- did those ever come in K5s?
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    most of the time if it has a stick it has a 205, an auto has a 203. the 208 didn't come until 81.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    208's did come in k5's but not till much later. More than likely you have a 203 in that year. Another good way to identify a 205 is that three bolt round cover right in the middle back side on the picture above.
  7. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    So if I have a NP203- how hard would it be to put a 205 in? Just a longer drive shafts?
  8. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    When I put a 205 in my 74 K20 plow truck in place of the 203,the rear shaft fit ok(except the transfer case had a half ton U-joint flange,my 3/4 ton u joint was larger,had to get another rear yoke)but the front shaft was way too long--I searched the boneyards and came up with a shaft from a 69 K10 that was very short,fit perfect--or I could have cut the old one down and welded the yoke back on,something I now have to do,since that short shaft wasnt the greatest shape,the spines are real sloppy.I have a brand new shaft that is longer waiting to go in after its shortened,but I have been debating whether to part out the truck,because its so rotted--decisions,decisions-- /forums/images/graemlins/tongue.gif
  9. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    208 - upside down... /forums/images/graemlins/screwy.gif
    tag
  10. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    the EASIEST way to tell....is to look at the shift pattern
    208-2hi-4hi-nuetral-4low
    203-4hilock-4hi-nuetral-4low-4lowlock
    205-4low-nutral-2hi-4hi
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  11. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
