How to id my dually rear
Discussion in 'The Garage' started by camiswelding, Jun 20, 2005.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    What I thought was a 14 bolt is not... I changed the fluid when I got the truck but never gave the rear a second glance
    1989 v3500 crewcab 3 + 3
    rear has 10 bolts... full floating... squared off at the bottom...
    how can I determine if its a d60 or d70... Ive looked at pics and they look the same to me
    truck is factory stock
    cam
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    D60
    D70
  3. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    thanks taz... thats a pic I can understand
    cam
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Np, its actually on this site in the Tech Section at the very bottom :thumb:
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I've got the same truck if it is a pick up bed dually. It is a Dana 70HD. The only other dually rear end that would work for the dually pick up bed style truck is a wide track 14 Bolt FF and I'm pretty sure that only went in 90 and 91. You already figured out it isn't that one!
    Contrary to what some think, there was never a Dana 60 dually axle made.
    If it's a cab and chasis truck, post up.
    Eric M.
  6. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    Those pics remind me of those little books you used to get as a kid where they had 2 almost identical pictures on the same page and you had to look for the tiny differences :haha:
    Other then the extra 2 lines where the axle tubes would go those pics look identical to me :grin: I'm sure somebody will say that the d70 in the bottom pic is bigger but that wouldn't help out much when your comparing a 2inch pic to a axle under your truck :D
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Look under the lower diff cover bolts- the housing sticks farther down on a D70.
    GM used the D70HD under older dually pickups. Why? Who knows.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Cam, go measure the tubes. If they are 4" diameter, its a D70HD. :cool1:
  9. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    They never put rear dana 60's in the 89 dually crew cab. It should be the 70HD as mentioned above :D
  10. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    If the cover has never been off, there is a tad attached by 2 of the bolts. It will tell you gear ratio, posi , and rear end model.
  11. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    I got a Dana 70 out of a 89 dually Chevy and mine is a 70HD3 ,it has 3.5 dia
    tube and is necked down at each backing plate flange. It also has the largest pinion offset and requires a fiew parts that are unique to this model. If you have a HD3 it will be cast twice into the center section, one that can be seen from the front and one the rear. The best way is to call Drivetrain Superstores with your BOM# and there will be no guess work. The BOM# is located on the tube about 6-10" from the cast end and is a 6 digit number(I think?) . It was stamped in so lightly that I had a very hard time finding it.
    Good luck Jeff
