How to identify a PTO x NP205??
Discussion in 'The Garage' started by rockspider, Oct 1, 2004.
  1. rockspider
    rockspider Registered Member
    Sep 9, 2004
    37
    I've found a PTO at the wreckyard, the guy there didn't even know what it is, nor had any idea what rig it came from.
    It's a Chelsea (Dana Corp.) and the small label says model: A2MHNW 2C, assy: D75
    I agreed with him that he'll keep it for me and in the meantime I had to find if it's good for my NP205 or not.
    Any idea before I buy the wrong one?
    The bolt pattern looks the same as the 205 side opening, but what about the gear inside? /forums/images/graemlins/confused.gif
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The bolt pattern is an SAE standard so they are all the same. A Chelsea dealer can help you ID the application. Try a big truck parts supplier in your area.
  3. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    sorry for my ignorance...but what exactly is a PTO anyways? /forums/images/graemlins/dunno.gif /forums/images/graemlins/whistling.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Power take off. It's a little gear box that splines into your transfer case. From there you run a driveshaft to whatever you're running, in our case it'd most likely be a winch. /forums/images/graemlins/thumb.gif
    For others it might be a hydraulic pump or something.
