how to identify t-cases ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smp, Nov 29, 2000.
  1. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    Is there a web site that has t-case id's ?
    [​IMG] SMP
  2. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    SMP,
    Here's some pictures of 203's and 205's.
    http://www.chuckschevytruckpages.com/drivetrains.html
    Your profile states you have a 72, so I imagine you're not interested in 208's and 241's. If you are, then check them out, they should have a circular ID tag on them. I think the earlier t-cases had the tag too, but mine and other 203/205's I've seen no longer had them.
    It's not what you buy, it's what you build!
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    My 208 has a red circular tag on the lower rear face, with the build date, model # and the serial # stamped right on it.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have a ? about this site it says that a 203 has the speedo on the driverside and the 205 has it on the passinger side. ok why dose my 205 have the speedo on the drivers side? and yes i do know 4 sure that it is a 205 and not a 203
    s.smith 77blazer lookin 4 mud
  5. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    ok great website, but now i have another question. on my 72 blazer the speedo cable is on the drivers side on a np205 and on my doner 80 k30 the speedo cable is on the passenger side on a np205 is this right?
    [​IMG] SMP
  6. talldogg
    Jul 26, 2000
    754
    San Diego, CA
    Mudhog,
    Are you totally sure? You're looking at it from the back forward, right? Just asking 'cause I've got a 203 in my rig and a 205 sitting on my garage floor, and if I remember correctly, they've got the speedo cables set up just like the page says. I'll double check tonight, but I'm certain the results will be the same.
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Speedo cables can come either way on the 205, haven't figured out the ryhme or reason yet, but there is probably a rough year split. The one in my K5 came from a '72 and is on the driver's side.
    SW-ORD
  8. talldogg
    Jul 26, 2000
    754
    San Diego, CA
    I was currently looking for some other sites but I couldn't find any, and low and behold Stephen comes up with the answer. I guess I would have been confused too, if my 205 hadn't matched the site I referenced. Sorry to doubt you guys, I'm just sure of what I have, so I didn't leave any margin for variance.[​IMG]
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i was just thinking they swaped tail housings. but i am glad to learn that they do sometimes come stock on the drivers side. thanks 4 the info
