how to identify transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jim82, Jul 4, 2000.
  1. jim82
    jim82 Registered Member
    Jun 27, 2000
    71
    Bay Area
    I was wondering what kind of transfercase I have. Is there an easy visual diff between them? The truck is an 82, and I think the case is original but the 350/350 drivetrain is not so you never know. If anyone has pictures, or a good description, I would appreciate it.
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    My 81 has a round tag on the transfer case that has the info.Look on the backside (rear output).
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yeah it has a round tag on the back. I think yours is an NP208
  4. Big B
    Big B 1/2 ton status
    222
    fort worth texas
    IS IT CAST IRION OR ALUM.?
    bigb4x4.coloradok5.com
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I think the 81's were the last blazers that had the 205. I have an '83 that came with a 208. They're both 2 speed(hi low) The 205 is gear driven and cast iron. The 208 is chain driven, made of aluminum and is bolted together. Hope this helps.
    creepin' and crawlin'
    Jim
  6. jim82
    Jun 27, 2000
    71
    Bay Area
    Thanks for the info, found out its 208. Was kinda hoping it was a 205.
  7. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    No doubt, I have a 208. It works well but I'm always a little leary about it. I've heard some scary stories and sometimes mine makes the same noises as the ones in the scary stories!
    Jim
  8. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    dont worry about it untill it breaks! My 208 has put up with some crap and is still alive. Just be sure to service it!! I got high centered on a big terrace and all of the weight of my truck was on the tcase and crossmember and it is fine.
