How to install a 1 piece rear main seal?
Discussion in 'The Garage' started by garlicbreath, Jul 28, 2006.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I finishing the assembly of my 91 350 and am down to the oil pan and rear seal. What is the best way to install the one piece rear main seal?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    just install it like any other seal, make sure you use a gasket between the block and the seal adaptor. Just lube up the shaft so the seal is not dry when you first start the engien up
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    lube the inside of the seal and the end of the crankshaft, bolt it on, and go.
