How to install a cb?!
Discussion in 'Communication (CB | GPS | HAM)' started by 82Jimmy, Jul 18, 2000.
  1. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    I got a cheap midland...going to put it in temp. so what do I hook it to? theres a black negitive wire and a red wire...thats it!
    <font color=blue>If its too loud, your too old.</font color=blue>
    <font color=red>Cameron</font color=red> <font color=green>Burnett</font color=green>
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    That's all you need!
    Black = chasie ground (metal)
    Red = Hot + side of fuse box
    then srew the antena cable in the back and plug in your mic and talk away
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  3. 82Jimmy
    Jun 9, 2000
    702
    can i hook it to my postive side of my battery?
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    On the red wire, I have always (and will always) ran that straight to the battery with an inline fuse. There are a lot of little power surges from the system that you never see but will make short work of a CB. Mount the antane somewhere were you'll have a good ground plane. As soon as everything is hooked up, resist the temptation to start yacking and go to a cb shop and have them set the SWR. If they are set wrong, then you're radio won't talk worth a dang and you might tear something up.
    BTW, midland makes a DANG good radio. I've never had a problem with any that I've run. I've still got two sitting in the garage. Probabbly gonna use one of them when I make my President a base unit.
    Kyle
    89K5
  5. Burt4x4
    6,854
    Yes, but make sure you have an in-line fuse so incase of a short you won't smoke your CB.
  6. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
  7. 82Jimmy
    Jun 9, 2000
    702
    What amp should the fuses be?
  8. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    2 amp fuses. BUT if you do not want to wire your cb into the fuse box, but a DC adapter [ciggerette lighter thing] and cutt off the end and then wire the 2 together.
    i have found with a k5 Blazer that a whip antenna on the bumper is 100 times better then a magnetic mount. what do people think.
    also if u need advise on installing a P.A. email me @
    Confederate9@aol.com
    '85 K5: BIG BAD AND MEAN
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I just put a cigarette lighter plug on mine, so that I can take it out when I want to.
    YEEEEE HAWWWWW[​IMG]
  10. Kyle89K5
    2,273
    OKLAHOMA
    I agree that a whip on the bumper is better than a mag mount, depending on what your doing. I run a 5' Mag mount Wilson 1000 on the top of mine and very rarely hit anything, but if I do and I am going fast enough, off it comes. I use my CB daily and like the way it works with the Wilson.
    Neil has got the whip thing down to an art on his
    That's right, I stole somebody elses pic.
    With the top off, I can reach up and take the ant. off it's base with out ever leaving the seat of my truck, so I'm pretty comfortable with it. It all depends on what you're doing with it I guess, I get a better ground plane by having mine off the steel roof of the cab rather than off a fiberglass or no top.
    My $0.02
    Kyle
    89K5
  11. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    wilson makes a roof mount you put a hole in the roof and mount the wilson it has gaskits and mine has never leaked or come off and I have hit all kinds of sh!t
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
  12. Kyle89K5
    2,273
    OKLAHOMA
    I'm just hesitant about lopping a whole in the roof of my truck. The CB shop where I got mine offered it, but at the time I just didn't want to mess with it. I've only knocked mine off twice in 3 years so I feel pretty good about it. That wilson is a tough ant.
    Kyle
    89K5
  13. James90
    May 18, 2000
    986
    Rocky Mount NC
    well I did not haft to make a hole the guy that had my k5 before me had the roof mount so I reused the hole with a new wilson 5000
    [​IMG]Go prepared
  14. Kyle89K5
    2,273
    OKLAHOMA
    Good call. That ant. is a killer and will stick to the top of that truck through dern near anything.
    Kyle
    89K5
  15. Confederate9
    May 29, 2000
    1,686
    Greensboro NC
    well it u run a bumper mount, run the wires under the car up to the front where there is a hole in the firewall for wires and run it through there. OR runn it through the tailgait and run the wire through the truck.
    i have a 10 ft whip antenna on my bumper. i like it but 10 ft is like overkill 8 would have been better
