How to Install a Outside Tire Carrier
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77blazin, Mar 29, 2006.
  1. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    How do you install a new Outside Tire Carrier? I saw some here on CK5, but they are installed to the steel bumper, I have one that screws to the side of the corner panel, What do I have to do to put the bolts on?..
    I'd sure like to get those bumper type carriers but I don't think 4x4 Iron is making these anymore.
    Any help would do?
    Mike:dunno:
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    try blazenoffroad.com
    also check the vendor forum there are a few out there
  3. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    [​IMG]The ones that bolt onto the 1/4 panel are made by Valley. they are no longer made. I have put them on a couple trucks including my 89. There are brackets made from 1/4 plate metal that is treaded for the "nuts" and pre-bent to fit inside the 1/4 panel. If you don't have them, you WILL stress the 1/4 panel. If you take the tail lamp housing out, you gain access to the inner panels.
  5. 77blazin
    Mar 31, 2000
    394
    Honolulu Hawaii
    BaBlazer73,
    Hey Thanks for the info on the Valley Outside Tire Carriers:bow: , I have two of them waiting to be put on the 76 and 78 blazer, I have the inner brackets included in the kit (The one with the long rod extending from the middle of the brackets) I could never figure out what was that for.:confused:
    Both are brand new in their boxes, I never thought that going through the taillight lens hole was how to do it, I thought I had to cut out one of the supports, that would suck.:hack:
    One more question, Whats the size tire that can max out on these carriers without weakening the quarter panel?:1zhelp:
    Mike
  6. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    I had a 31 with a steel rim on my 76, it made the 1/4 panel sag, but it wasn't 100% metal anyways. The top of the 1/4 tipped in. I guess the key is to make sure the part on the tailgate itself will "lift" the carrier up. thats what I did on my 87 with the same tire. worked better. I have a bald 33" on an 15x7 aluminum rim for the 89.
