How to make a snorkel?
Discussion in 'OffRoad Design' started by ChevyCaGal, Oct 11, 2001.
  1. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I have no clue where to even begin... is there a write up somewhere where I could get really basic simple step by step directions as to how to make a snorkel? I'm talking like instructions a 5 year old could get because I want to get it totally and not mess it up. I don't necessarily want cheap to make a cheap one either. But not one really expensive... like under a $100 bucks would be good. Something that doesn't look like they taped some pcv pipe up with duct tape... anyhow any help would be appreciated. Thanks! [​IMG]
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
    Suck Fumes Ford Boy
    Quit shooting corn at me!
    &lt;&gt;&lt; PSALMS 23 &gt;&lt;&gt;
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    PVC is gonna be the only snorkel you could make for under a hundred bones. Send a pm to Thumper...he did his own snorkel.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Hey Steph ... Check this one out ! <a target="_blank" href=http://www.off-road.com/chevy/tech/snorkel/>http://www.off-road.com/chevy/tech/snorkel/</a> Thumpers is also very cool !
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    GO BUSH
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    How about having a muffler shop bend up some 3" (or larger pipe) instead of going the "plumber's special" route. Might look a little cleaner without breaking the bank.
    Real trucks don't have spark plugs!
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Doing a permanent installation that looks good for little cash probably isn't going to happen. I know of several vehicles with converted ARB snorkels from FJ60's I think, that seems to work out OK for lower output motors, but I think it's really going to choke a larger motor. We had a custom plenum built, cost about $120 or so for a sheet metal shop to build it, then a couple hours of our time to finish building it like we wanted, oops. would have been easier to do it all on our own I think. We went from there to 5" semi truck exhaust tube into the cab through the heater hole, then ran a conical filter under the dash. For the tank trap, we necked down to 4" PVC and ran it up higher. I didn't want to choke the motor, and evidently didn't. I had no idea we took the acceleration by a full second!
    I wouldn't run a snorkel full time, it's just too hard to get a big enough tube out of the engine bay while not obstructing vision or being vulnerable to getting knocked off by a rock or tree. A cold air intake from the grille is what I'm after for the final form. I'm not too worried about deep water, I can drive in 4 feet of water and just barely be over the tires! I don't have anything like that around here.
    Engine output and air demand is the biggest problem. for a small block, there are a LOT of intake systems that will get you a plenum (bolts to the carb/throttlebody) and some tube to start with. from there, I don't know what to tell you. For a big block, you'll probably just need custom parts to get big enough tubing.
    Hope this helps!
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
