how to make steel tubes for qjet
Discussion in 'The Garage' started by wazzabie, Aug 26, 2005.
  1. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,719
    5
    Washington State
    Where can I get a tool that will make something like a double flare at the end of steel lines. I need to be able to make the end of my tube so that I can attached a rubber hose onto it. It is lie a lip but then goes back down. This is the part that goes into the carburator. It is a press fit and has a flare. The flare is not the same as a double flare which bends upon its self.
    So the tubes should not look like this in the picture. They ends need to go back down.
    http://www.wttool.com/Merchant2/graphics/00000001/normal/66020141.jpg
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    hyperlink
    What you need is a double flaring tool. Most flaring tools come with double (inverted) flare attachments. They are small round pieces that fit into the end of the tube to make that 'bubble' shape as you tightned them. I know Advance sells a whole kit in the AmPro brand, most likely Autozone too. Lisle has the tools too. Just check your local parts store, or maybe even a decent hardware store. Just ask for a flaring tool with an inverted, or bubble flare attachment.
    EDIT:
    To give you an idea:
    http://www.toolsource.com/ost/produ...3880&mscssid=AA2A5W44MVC29HPV8MEGCP4Q4DKGDS57
    The double flare attachments are the round things on the right side of the picture.
  3. wazzabie
    Apr 17, 2001
    1,719
    5
    Washington State
    Double flare goes back in on its self.
    What I need to do looks like this:
    http://www.4wheelnoffroad.com/qjet/vc-592f.jpg
    It is the flare on the tube out of the carb. I would like to make my own.
    I have two carbs with both of them bad.
