How to mate an NP205 to a 700R-4?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by realsquash, Nov 22, 2000.
  1. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  2. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Get a TH350 version 205 from a 1980 1/2 or 3/4 ton ONLY!!! These were of the round pattern, 27 spline and will bolt to your 700...although why anyone would mate a bulletproof transfer case to a marginal transmission is beyond me, but to each his own! More power to ya!!
    ken
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    My 205 came from a 72 blazer with a TH350. I got a short shaft from advance adapters, dropped the tranny to have the shaft put in, and it bolted right up. My 700R4 is an 87 model and has a square 4-bolt pattern where the t-case adapter bolts up. It matches the factory adapter that came from the 205, also the same pattern found on TH350's. Make sure you get the adapter with the t-case. The 27 splined adapters and sleeves are getting hard to find. Also, do a search for past posts, you might find more info.
    BIGJ
  4. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    If you are on a budget get a 205 and adapter for a 350. Cut 1/2 inch off of the tailshaft of the transmission and buy a 1 1/2" spacer used to mate a turbo 350 in place of a 700r4 an put it in front of the adapter. It will bolt up perfectly. I ran this setup for 4 years with no problems. I purchased the adapter for about $50.00.
