How to measure caster?
Discussion in 'The Garage' started by BigCountryx, Nov 12, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Can it be measured from the kingpin cover? Seems like the best place would be a flat surface 90* to the kingpins. I'm thinking a driveline anglefinder on top of my x-over steering arm would work. :confused:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    All the research i did tells me no.
    I was all about measuring it when i relocated and lengthened my front shackles, but everywhere i looked for the info told me that it can not be accuratly measured without an alignment rack.
    Anyone else have any thoughts?
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You are correct, you CAN measure for caster angle using an angle finder on the steering arm of a D60. The reason being is because it is 90* to the king pin centerline as you said.
