how to measure leaf springs....
Discussion in 'The Garage' started by RootBreaker, Jun 1, 2006.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so this is going to be a long post.. the jist.. how do you tell what size lift leafs you have????
    so now the easy question is out... the long post :haha:
    back in 1997 I had a guy lift my truck.. so it would pass nj strict lift laws (and I had a dirt driveway and not the tools like I do now :bow: )
    so he put 12" rear leafs on the truck and 13" fronts
    I already had a 3" body lift
    was going with rockwells and 53" michelins.... well nj changed their lift laws so I had to bring the truck down... it sat for 7 years..then viola end of 2004 on the road....
    I went from this (without body lift)
    just realized the rear block is already removed from the drivers side.. and pass side is up in the air via hilift jack...
    this will give you an idea of how high the back was...
    to this
    now here is what I did...
    I took the 13" front leafs off.... put superlift softride front 6" leafs
    removed the factory tapered block from the back
    the block is like 2.5" on one side and 2.75" on the other....
    howevever if you look at the pics.. I supposedly still have the 12" rear leafs on the truck... how can I tell if they are really 12's or if it was 12" with my stock block equaling say 10" leafs plus my block?????
    that would mean remove block and it is like close to 9" rear....
    any help... just curious... a bud was over and I told him my rear 12" leafs were still on the truck.. and we were looking and the math isnt adding up anymore??????? :crazy:
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    cmon 19 views!!!! no replies????
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    so right now you have 6" front springs, unknown rear springs and a 3" body lift?
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    6" front springs
    unknown rear
    that is it....
    my server was down and I have only a few bigger pics of my truck...
    this was with the 12" susp and 3" bl...
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you should have 8" rear springs... witha 12" kit the rear springs are 8" not sure aboout the 2.5" bolck though...
  6. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    im not sure they even make a 10" rear spring? i had a set i picked up and called skyjacker to find out what size the were, they told me run a string eye to eye then from the string to the bottom of the leaf pack and that is what size it is, if they are off the truck then they will be a couple inches off unloaded.
