How to measure lift
Discussion in 'The Garage' started by 53chevy, Jun 4, 2006.
  1. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    I'm looking to purchase a 84 1 ton, the owner says it has a 12 inch lift , is there a way i can measure the springs to see what the lift height is. Thanks
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I think the only company that makes a 12" kit is Superlift, they will have the part number on the spring, if it's still there. It will be a yellow tag, some numbers, and the last set of numbers will be the lift. Might be a dash then the number, in your case a 12. What size tires are on it?? How much space is in the wheelwells??
  3. goldwing2000
    goldwing2000 Guest
    You can measure the distance between the axle and frame arch and then post the numbers on here. Someone with a stock truck (or a known amount of lift) can then measure their truck and the difference will tell you how much lift you have.
  4. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    It has 39.5 inch boggers, about 13 inches between the top of the tire and the center of the fender.Between the axle and the frame arch is about 16inches. Thanks for the help
  5. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I found this, (man I love the internet, soooo specific and I still found something pretty much identical to what he's buying).
    This '86 has 12" of lift and 39.5" boggers...
    Looks great to me but then again I'm an altitude kind of guy, forget flex!
    -Avery
  6. goldwing2000
    goldwing2000 Guest
    Is that front or rear?
  7. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    that is front specs.
  8. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    side note: I like the new Chevy trucks, but man there isn't a truck out there that looks tougher, or better than an older 73-87/91 Chevy. That's one bada$$ truck! :saweet:
  9. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    that is why I had 12" susp and 3" bl.. was going with rockwells and 53's
    however I found a way to legally drive it in NJ..... but that is next years project..... :wink1:
