How to mount electric fuel pump correctly?
Discussion in 'The Garage' started by bajaviking, May 11, 2004.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I am running a 454 with a q-jet and an electric fuelpump. What I want to know is should I mount the pump close to the carburator or close to the tank. Should I mount it as high as posiible or as low as possible. I am running a Autozone generic fuelpump which I suspect is not up to the task of pulling enough fuel through the system, do I need a high volume pump and if so can someone recommend me one. /forums/images/graemlins/dunno.gif
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The pump is most likely a pusher type so it will need to be as close to the tank as possible. I would mount it low (on the frame probably) so it stays primed.
    Beware, most of the other aftermarket pumps (Holley, BG, Mallory, etc) will require a regulator.
  3. bajaviking
    Apr 10, 2002
    752
    Baja
    Before when I ran the q-jet on the small block with mechanical fuel pump I never had any problems on hill climbs, now with the same carb it stumbles and I don't know if it's because the q-jet can't feed the big block or if it's because the electric fuel pump can't keep up. Your opinions are much appreciated. /forums/images/graemlins/ears.gif
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you want to mount it close to the tank and below the tank. Electric fuel pumps are MUCH MUCH more efficient pushing fuel. Meaning if you can minimize the amount of pulling it had its will be more efficient. What kind of pump is it? Just some generic thing? I wouldn't expect that to be up to feeding a big block.
  5. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I have used that autozone cheepy pump and I went through 4 of them (life time warranty of course) and they couldn't feed my small block but I did have it mounted under the hood. I now use a holley red and have it mounted on a custom bracket that bolt the the cross member right infront of the tank. It has never let me down. I have thought about going with the holley blue that has and requires the regulator but have not made the switch yet...Jason
  6. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Like this.... Nothing has worked better for me than this setup. Daddy told me a long time ago, you get what you pay for. As it stands, this system has not let me down.
    John
  7. sr175
    sr175 Registered Member
    Mar 31, 2004
    76
    Tracy, CA
    Have to agree with the previous posts. I got one of those kragen electric pumps /forums/images/graemlins/doah.gif and mounted it on the wheel well next to motor. Big mistake because electric like to push not pull. Fuel pressure was spuratic and only got to 4psi. Would not work when hot outside. Was gonna mount next to and below tank but was easier to put mechanical back in. With mech. I get constant 8PSI now and no loud electric pump. I have watched a couple posts here regarding pumps. If I go back I will probably do what they talked about in the posts. In-line bosch pump. Will see. Have bigger fish to fry next for me! Tune engine, steering, lockers, gearing, tires.......... /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/hack.gif
    It never ends. Pismo is coming up /forums/images/graemlins/peace.gif and truck is acting up!
  8. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    huh, sounds like a real problem for you guys. sure wish i didn't have tbi so i could enjoy in your pains. too bad. as far as the sr175 guy goes well he's just a hair away from a ford style break down. 98% still on the road huh. 2% can actually make it home. how sad. guess i'll just have to keep helping him till his truck turns into a K5.
    ironic i may be starting working for a ford dealer. i'll do my best to try and get that average up to 3%.
  9. bajaviking
    Apr 10, 2002
    752
    Baja
    How much was your Holley pump and where did you buy it. Thanks for al the input everybody.
  10. dyeager535
    26,980
    Is there any reason you aren't running a mechanical fuel pump?
    I don't really have anything against electric pumps, but to do it right costs a hell of a lot more than going with the stock mechanical ones that work flawlessly. Also seems to generate more problems for some of the people that do the swap. (my dad was in the same boat when he went 454, electric just wasn't cutting it)
    Instead of dumping more money into yet another electric pump, and having to re-plumb stuff under the truck, it might make more sense to use the mechanical, as long as it's an option.
  11. bajaviking
    Apr 10, 2002
    752
    Baja
    I think the engine I got is from a newer year because it came with a block off plate where the fuelpump goes. I don't know if the internals are ready to just put a pump in there or not /forums/images/graemlins/dunno.gif
  12. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Dorin this is my problems I have a 95 motor in a 82 truck and the newer motor didn't have the hole for a fuel pump push rod....Jason
  13. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    Under the block off plate, everything is there you need to just put on a mechanical one. I have a mechanical and an electric that i run at the same time. Once I bypassed the mechanical one jsust to see what would happen, and it was fine till i gave it over 1/2 throttle, then it got a little rough. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
  14. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I'm running a street/strip carter inline electric fuel pump and so far I'm very pleased with it. The carter replaced the red holley which leaked all the time. Holley was old too but still happier with this one as it is very quiet and provides plenty of fuel.
