How to mount shocks on 14bff that angle inside the frame rails??
Discussion in 'The Garage' started by 85mudblazin, Aug 24, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    i have seen them before but I forgot what they are called, they mount to the axle them angle up in between the frame rails where they are mounted on a crossmember type thing, but how do you mount the shock to the axle tube so that it can still flex??
    -Chris
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i used the kit from mo off road here is a cupple of pics [​IMG] [​IMG]
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    an easy is way is to use c channel, drill a hole, put a bolt through it and weld it there. it fits on the tube nicly.
