How to possitively ID axles????
Discussion in 'The Garage' started by chevyfumes, Oct 25, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I went and looked on the axle chart but it dosent say anything about them having anything stamped on them, it says stuff like the 14 bolt looks deceptily like a dana 70. So how do you know when you've found a 14ff and a Dana 60.... /forums/images/graemlins/confused.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    14FF has a pretty smooth cover compared to a D60 which has a fill plug on the right side of it.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Well, a 14 bolt really looks nothing like a D60 or D70, but the easiest way aside from that would be that the 14 bolt has 14 bolts holding the cover on, the 60 and 70 have only 10. </font color>
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    So how do you tell if it's a FF or a SF for the14... And how do you tell if they're 3/4 or 1 ton, with all the arguing going on I'm really confused.... /forums/images/graemlins/smirk.gif
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> SF has a nearly round cover, the FF has the pointy part on the bottom. FF has the hubs that stick out in the center of where the wheels bolt on, the SF looks like a 10 or 12 bolt out there. 3/4 or 1 ton really doesn't matter, FF is a FF is a FF... /forums/images/graemlins/thumb.gif You could measure the spring perches to see what it came from, but the axle itself is the same. </font color>
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Ok. I found a 14 bolt ff that came off a 88' 3/4ton sub w/454 and towing pkg...the guy selling said it has posi on it stock...hes checking the ratio this weekend....do you know much about this axle?
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    I find it hard to believe that an '88 Sub would have a Full Floater rear in it.
    I would almost bet everything that it has the Semi Floater in it instead.
    Unless someone else swapped the Full Floater in it?
    Take a look at the hubs. If you can see a bearing hub protruding past the wheels, its the FF, but if you don't see the hub sticking out, its the SF. /forums/images/graemlins/wink.gif
  8. TONYP
    Aug 13, 2002
    2,116
    so cal
    i asked the gut that and he said it came with the 454 and the heavy tow pkg. so to be a full floter the hub pac will stick out....and would or could it have a posi unit in it...
    now what if it the SF? /forums/images/graemlins/ears.gif
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ohhhhh, so the Sub is a 2wd? 454's were never available from the factory in the 4wd's.
  10. TONYP
    Aug 13, 2002
    2,116
    so cal
    yes...and I just posted a guestion about the diff. from a FF vs. SF...
    I guess what I'm looking is a 14FF with a locker in it..
  11. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Easy, just call me........... /forums/images/graemlins/cool.gif
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah...call Frank! /forums/images/graemlins/cool.gif
  13. TONYP
    Aug 13, 2002
    2,116
    so cal
    just PM'ed you
  14. chevyfumes
    Feb 24, 2000
    38,584
    266
    Why you got one???? I want dibs unless it's too late now... /forums/images/graemlins/tongue.gif
