How to pull a stump?
Discussion in 'The Garage' started by Skigirl, May 15, 2003.
  1. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    OK, guys, I may have a chance to pull a stump out of the ground with my truck. I think it'd be fun. /forums/images/graemlins/thumb.gif Just don't know how to do that. Chain? Strap? How to connect whatever it is to the stump? And I expect there should be some kind of rope or something to keep the stump (It's not huge) from being flung into something it shouldn't fling into /forums/images/graemlins/eek.gif(it's by a driveway, so could hit stuff).
    I'm /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Run a chain or strap over a large tire and down to the roots (dig as much as possible and cut as many roots as you can find first). This will make your horizontal pull into a vertical pull.
    Then it would not hurt to attach a safety rope to keep the stump from flying too far also /forums/images/graemlins/thumb.gif
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Just keep the strap low
    you can use a chain(I have) but chain do snap if you yank it(getting a running start) where a strap will usually strech /forums/images/graemlins/thumb.gif
  4. stuper
    stuper Registered Member
    Mar 8, 2003
    60
    PA, Luzerne
    i was pulling decent sized shrubbry out of my aunts, i hooked the tow chain around the base of the tree by the dirt and the other hooked to the tow hook. i put it in 4 low and just a steady forward. don't gun it just let ur torque work for u. my .02.
    theo/stuper
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I just pulled a couple of stumps with my K5.
    If it is a big stump you will have to dig out all the way around it and chop off all the big roots or you will ruin your truck trying to pull it out.
    Once you have all the big roots chopped off wrap a chain or strap around the stump so it wont slip off.I personally perfer chain because it bites in and holds better.. Put your turck in 4lo and gently give it the gas and let off then gas it again and rock the stump out of the ground. Use the weight of the truck to pull it more than using a lot of power. This will save wear and tear on the drive train.
  6. Skigirl
    Apr 2, 2001
    2,563
    Thanks guys! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Hook a "choker" onto the stump, hook another cable to the eye of the choker, and to the bumper bracket of the K5, leave about 15' of slack, put in gear, mash the throttle down, kick it in neutral before the slack is taken up, this way no damage will occur to the drivetrain, while the offending stump is "banged" out of the ground. /forums/images/graemlins/grin.gif
  8. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    It is way easier just to dig it out w/ a backhoe...
  9. Skigirl
    Apr 2, 2001
    2,563
    No backhoe. K5. /forums/images/graemlins/thumb.gif
  10. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    I can see the post tomorrow.......how to replace reverse gear in ________ (insert your fav auto tranny here). I was pulling out a stump and when trying to hit neutral I accidently knocked it into reverse.
    -Scott
  11. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    It is more fun to use one of these;
    There is no stump to get rid of after you are done /forums/images/graemlins/grin.gif.
  12. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    my dad did this with his 79 3/4 4x4 a few years ago. it was a pretty big root..it was fun watching the tires gripping the pavment and skidding a little...he put it in 4low as well and slowly pulled it..
  13. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    My thoughts exactly!!!! /forums/images/graemlins/thumb.gif
    Pam- Trust me when I tell you that it's WORTH THE MONEY to hire a hoe for an hour. A good hoe op can dig out a big stump, roots and all, in less than an hour.
  14. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    but this way is wayyy more fun /forums/images/graemlins/thumb.gif
  15. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    [/ QUOTE ] And you expect me NOT to touch this one right.... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  16. Skigirl
    Apr 2, 2001
    2,563
    Yea Paul, I have no doubt that a backhoe is easier. But it's for my best friend and he doesn't have the dough to spend on anything right now. They just moved (had to with no notice) /forums/images/graemlins/eek.gif, his wife just had to get the top of her arm replaced with a prostethic /forums/images/graemlins/eek.gif (ski injury crushed it) and they had to pay cash for the surgery and she's an artist so their income has been sliced in half /forums/images/graemlins/eek.gif. So, I'll use the truck.
    And a backhoe doesn't sound like nearly as much fun! If it was a huge stump I probably would rent the thing myself. But I think it'll be easy. And it'll give me practice doing cool stuff with this truck!
  17. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    HAHA /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rotfl.gif
  18. Skigirl
    Apr 2, 2001
    2,563
    Ya beat me to that one fumes! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  19. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    SkiGirl, when the stump come's out, it just roll's out onto the ground, like a turd, it won't fly, or catapult, unless You have like 50' of slack in the cable, or chain, when it pop's out. /forums/images/graemlins/eek.gif
  20. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Don't listen to that smack Pam. Pauls just a rotten old hoe operator. What You need is a good dozer operator like Myself. Just drop the blade and shove it right out of the ground. Now there might be some driveway damage but hey it wont take an hr like some slow-ass hoe operator. /forums/images/graemlins/rotfl.gif
