How To R & R Hood Release Cable 87 Chev Suburban??
Discussion in 'The Garage' started by Dave1, Apr 6, 2006.
  1. Dave1
    Dave1 Registered Member
    Jan 4, 2002
    82
    Winter Springs, (Central) Florida
    Went to open the hood of my 1987 Chev 3/4 ton Suburban the other evening, pulled the T-handle under the dash, and it pulled out about 8-10 inches. Luckily the hood opened.
    I looked under the hood and saw where the cable housing had deteriorated and broke apart.
    What is the process to remove the old and place a new release cable??
    Can the hood be opened manually without the use of the cable? If so, how?
    Thanks, Dave
  2. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    i hate having to go inside the cab to open the hood i plan on running a shorter hood release cable down behind my bumper to save me a few steps when i need to open it.
  3. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    they are simple,
    youll see as soon as you look at it under the dash there, what you need to do to remove it
    youll need to pull it through the firewall into the cab area to get it out of the truck
    its simple really
    i dont remember the details since its been a while since ive removed one from a rig i was parting, but i have some of these cables laying around still i know
    of all the rigs ive been around and owned ive never had a problem with one, other than the handle coming off
    wierd.
    good luck
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    not a bad idea, but i have to much expinsive **** under my hood to allow someone easy access to it
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    2 or 3 screws hold the handle assembly in place under the dash. Remove those and then pull the old cable into the cab and discard. Install new cable. :)
  6. chrisb420
    Aug 6, 2004
    652
    Binghamton, NY
    i like the idea of protecting my stuff also but my truck is a full convertible with no doors so running it behind the bumper is actually more theft prevention than the stock location.
