How to raise seat?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DougK20, Mar 26, 2003.
  1. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    I have an original bench seat. It has been recovered and looks/feels brand new. I would like to raise the seat up an inch or two for better visibility when wheelin. Also, I have very long legs. Any suggestions on how to raise it, brackets and all?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Longer mounting bolts and spacers bewteen the bracket and the floor.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I just raised my seat 1.5" by putting some square tubing that was 1.5" thick down and setting the seat on top of that and putting in longer bolts.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> spacers won't work on the trucks since the floor is different, at least it wouldn't work on my 78. I think you'd have to cut the seat frame and weld in a section, but I don't think I'd trust that. </font>
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    small chunks of 2X4
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    small chunks of 2X4
    <font color="green"> Sounds safe! /forums/images/graemlins/eek.gif </font>
  7. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    maybe u could use spacers and longer bolts between where the seat bolts to the seat frame. should be flat and fairly straight forward to lay in spacers that way. I think.
  8. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    As I'm sure you've already figured out the front two mounts are on an angle. You'd have to reproduce that with the brackets when you make them. The back ones are a piece of cake.
    When you make them, make them out of metal. You'll also want to bolt that new bracket to the floor through the current hole and a new hole in the front. Otherwise the seat will have a habit of "rolling over" the bracket.
  9. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    small chunks of 2X4
    [/ QUOTE ] Tell me about it! There were "small chunks of 2x4" under both of my front seats /forums/images/graemlins/blush.gif when I bought my /forums/images/graemlins/k5.gif... Scary thing is, if I didn't keep hitting my head on the ceiling (I'm 6'4'') I would have never looked and they'd probably still be there /forums/images/graemlins/deal.gif
  10. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    i also have long leg's and have raised the seat in every pickup i've had.
    take the seat out flip it over
    there should be 6 bolt's holding the slides to the seat
    take those out, put some little nipples (short peaces of pipe from hardware store) between the slides and seat, put in longer bolt's.
    i think the pipe you need is 3/8.
    that way you have no cutting and they are are the same lenth.
    about 1.5"s is the longest i can go, i tryed 2" once but my head was to close to the roof.
    1.5"s gives you a lot more room.
    but you really need tilt wheel or you're leg's get cought in the stearing wheel when getting in and out.
    good luck
    dave
  11. DougK20
    Feb 18, 2003
    384
    Boise, ID
    Thanks for your suggestions. I'll pull it apart and see which will work the best. Added more photos, check 'em out... Thanks again!
