How to read gear sizes, i think I have a problem!!! ***updated***
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yunit, Sep 18, 2001.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    How can I tell if i have 4.10's or 4.56 in my 14bolt and how do i tell what ration i have in my dana60 front? What are the markings on the gears? Please help me!!!
    rear 2 GM 327733 9 41 10 85
    front 8 2384 DANA D 30316 A3R143 41-9
    1987 Jimmy Sierra Classic, Palisades Park, NJ 07650<P ID="edit"><FONT class="small">Edited by yunit on 09/18/01 07:10 PM.</FONT></P>
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Re: How to read gear sizes, i think I have a problem!!!
    If you pull the covers off the ratio should be stamped on the edge of the ring gear. 41:10 is 4.10, 41:11 is 3.73...and I would assume 41:9 is 4.56, someone correct me if I'm wrong.
    The larger number is the number of teeth on the ring gear, the smaller number is the number of teeth on the pinion gear.
    Rene
  3. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    go to www.4lo.com an type you# in an it will tell you what you have
    can some 1 find me a ford i need to take a pee still peein on that ford just have to keep goin dam i can not stop pissin:) k5s kings
  4. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    I marked the drum and spun it around once and the pinion spun around just about 4 1/2 times, is this safe to go by?
  5. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    Spinning the drum is a good way to do it.You said that you only turned it one revolution.You must have a locked rear as with an open diff you have to turn the wheel twice.Of course the sure fire way to find out is pull the cover and get the numbers from the ring gear.
    chevrules...always has and always will
  6. chevrules
    Aug 26, 2001
    127
    Canada
    You have 4.56 front and rear.If the 10 beside the 41 is confusing you, that is because the '10 85' is the manufactures date of production.
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    You have 4.56 gears. 41/9 =4.56. I have the same markings on my 14B &amp; D60 I got from Roger and they are 4.56. It also has a tag on the bottom of the diff that indicates 4.56. What did you think you were getting?
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  8. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    Rene,
    Actually, according to the Executioner, 41:9 is 4.5555555555................
    Derf00
  9. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    The 41 10 thru me off. I am not a gear man. Ok now I feel a hell of a lot better.
    Besides that the internals of my 60 have almost zero miles on them and the 14 bolt has very too.
    Thanks everyone, have a good night. Pete.
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You better add that to yer signature Fred..."D60 and 14 bolt, 4.5555555:1 gears" Bawahahaha!
    Rene
  11. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Man don't scare me like this. Glad to see you got it figured out.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
