how to reduce trans temps
Discussion in 'The Garage' started by 01maroonz71, Apr 5, 2007.
  1. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    i know i know, 38's with 3.73's doesnt help anything, but my mileage on the interstate....but how can i reduce the temps in my tranny, they're hitting 250 after driving for about 30minutes or so. i installed the sending unit in the pressure port, which i hear is a bit higher, but i want it to be under 200 for sure, so i don't cook the fluid. when i checked the leve, it was ok, but a weird thing is that when i replaced the radiator about 2 months ago, when i unhooked the trans lines, no fluid came out at all....is that normal????
    thanks guyS!!!!
    dave
  2. otisringle
    otisringle 1/2 ton status
    Aug 2, 2005
    148
    california
    trying useing a trans cooler... Im no expert but that might cool down the fluid some........................
  3. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
  4. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    yeah...i already have a trans cooler in front of the radiator and i HD radiator also...truck never heats up past 180degrees, which is really screwin with me.
    thanks for the leak sweetk30
  5. sweetk30
    Nov 1, 2004
    25,552
    545
    have you been hittin the drink? you spellin is off a bit.... ( thanks for the leak sweetk30 ) :haha:
  6. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    damn, i ain't as think as you drunk i am
  7. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Make sure your converter is locking up. If it doesn't, that will cause excessive heat.
    I have two sending units on my tranny temp guage. One in the return line from the 28K B&M stack plate cooler, and one in the pressure port.
    The unit in the return line will read under 100 degrees , while the unit in the pressure port will read 250+ on trips of 20-30 minutes at interstate speeds.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    simple... ditch the radiator aspect of the system, just run it thru the biggest stacked plate you can find... garauntee it'll drop temps big time...
  9. sweetk30
    Nov 1, 2004
    25,552
    545
    but you need the fluid to warm up to a certin temp or it will cause damage over time. as taking it out of the loop might solve the problem short term.
  10. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    hmmm...interesting....maybe i just need to move the sending unit to the pan, that way im positive what the temp is. DPI, do you have two gauges??? do you know what your actual temp is????
    and also...how can i make sure my converter is locking up???? is there any way for sure?
  11. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    get into OD and lightly press the brakes. if your rpms go up, its working.
    just enough to activate the brake switch. so your lights come on.
  12. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah but he lives in fl, warm up shouldent be a big deal.
    where do you have the cooler routed? befor the rad or after?
  13. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    i don't have OD, just a th400... the cooler is after the rad. i bought the truck like that, but have no problem doing it a better way if there is one.
  14. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Look where he lives... Florida? I'd never consider running it thru the rad... It'd be stupid...
    And I run that way in Jersey... Awesome temps in the summer, 180, and it does get to a 150ish temp in the winter, just takes awhile.. It's a chance I'll take for the cleaner install and low summer temps...
    Btw, You should know I've certainly been involved in many of these discussions and know the "boiling off condensation" theory..
