how to remove a balancer without a puller?
Discussion in 'The Garage' started by sled_dog, Aug 2, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Tried the puller, my stupid ass grabbed coarse thread bolts and now the threads are boogered up pretty good. One bolt broke off in the balancer /forums/images/graemlins/doah.gif I've done dumb things before but I'm amazing myself right now.
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Drill out and heli coil the one with the damaged threads.
    Try a left twist drill bit to remove the broken bolt.
    You might have to drill the bolt out and heli coil it it.
    Good luck.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    drilled the bolt out, going to retap them all. A 383 crank is $150 for this motor so I think I might just say screw it and do that, so that will be a new balancer anyway.
  4. chrisp70
    chrisp70 Newbie
    Aug 2, 2004
    I had to borrow a puller from one of my neighbors. I let someone borrow mine you know how it goes. My nighbor owns a radiator shop. He said to put the center bolt back in the balancer loose about half way in. Then get an air chisel with a blunt punch on it. He said most of the time all you have to do is hammer that bolt with a little presure behind the balancer and it will pop right off. The vibration is the trick. If he is having a little trouble he adds some heat. I said Thanks for his puller because I don't have an air chissel either.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I got it. I tapped the holes to a coarse thread and ran the bolts in, they were a little loose but it worked well. Decided I'm gonna build a 383 so it doesn't really matter /forums/images/graemlins/smile.gif
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ***DO NOT DO THIS ON A GOOD BALLANCER***
    ive used a 3 jaw puller, it pulled the outside off. then put it on the inside and pulled that off.
    my ballancer was junk any way.
  7. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    Its not good to hammer on a crankshaft--the thrust bearings take all the beating,this leads to excessive end play and soon a seized motor. I'm guilty of using a 5 lb.sledge to put a balancer back on a few times ang had no problems,but I've seen engines fail a few days later after doing it that way too.
    I dont know of any good way to remove one without a puller--not one you are planning on re-using anyway--maybe chain it to another truck and drive away? /forums/images/graemlins/rotfl.gif
    I have seen someone weld a nut to the balancer and screw a bolt into it to pull it off the crank,but this method ruins the balancer and sometimes the crank snout too. /forums/images/graemlins/crazy.gif
  8. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    I went through this just this afternoon, like yourelf im gonna build a stroker, so i dont need the balancer, i took the oil pan off, and used a lond drift on the backside of the balancer to drive it off.
