how to remove doors
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, May 7, 2002.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    we keep talking about half doors and what not but what if we just took off the doors?
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    In some states it depends on where your mirrors are mounted. here in Vermont, you MUST have a driver's side mirror if the vehicle was equiped from the factory with it...most jeeps you see without doors are running mirrors that bolt onto the windshield frame...
    I'd think thats the only "draw back" to taking them off all the way.
    Brandy
  3. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Same thing goes in Cali... Need atleast the driver side mirror.
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    You ever tried takin one off by yourself...kinda heavy and you do need a mirrior...Dan
  5. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    i was looking at those half doors and the fact is im just too damn poor as a student to throw down 175 bucks for them. I can however use my own ingenuity to set up a mirror system. Seriously though if i wanted to take off the door besides the wieght issue are they hard to line up when you put them back on? whats the deal?
  6. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    just take a marker and draw around where the hinge bolts on and you would be set
  7. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    have any of you guys ever done it?
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Dunerunner bought a set of old doors he is going to Fab up some half doors..I am buying a set of the tube doors...Dan
  9. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    The mirror problem is simple. Go with fender mounted mirrors, or modify an ol;d door hinge to hold a mirror and just bolt it on when the doors are off.
  10. UseYourBlinker
    Jun 7, 2000
    11,117
    I had to pull of my driver door to weld the door skin. It was a pain in the ass of a job. The hardest part was lining up the door after reattaching it. Also fishing the wires through door was a challenge..
  11. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    Are there any ways to make this process easier. I really wanna try running without doors.
  12. sagechicken
    sagechicken Registered Member
    Feb 19, 2002
    71
    Wyoming
    I used the aluminum C.B. antenae mounts to mount my mirrors. I used self tapping sheet metal screws to secure them in the area behind the front fender. I will have pics as soon as I get them back from Walmart.
  13. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    There's been talk about modifying your pins to make them easy to pull. Then all you need to do is pul the pain and away you go. If you have power doors, get a quick realease for the wire and your done. Kpanza has this set-up and it works well for him.
  14. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    I was talking about the pull and play doors on jeeps and how to set them up on our righs. I would definatley be very interested in this set up. Since i dont have power doors i dont see it being real hard to do.
  15. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You could get one of those clamp on the front fender mirrors for cars pulling a trailer and take it off for trails.
  16. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Like Esteban said, I have this setup on my truck. I can't recall who put up the picture of the modified door pins, but if you do a search you should be able to find it. You basically remove the door pins (you have to grind off the small tab that keeps them in from the factory first), then drill the end of the pins for a cotter pin or other lock pin, re-insert the pins and there ya go! The best thing about this setup is that you never have to line up the door hinges again! You just pop the doors off and on and nothing else changes...
    As for the wires, I went down to the local electrical shop, and bought some 12 pin quick disconnects...wired in all of the power windows, speakers, door locks, etc and now I just pop off the disconnect, pop the pins out and I am set. I can do it all myself if I have to, but it is much easier with two people...
    As for the mirror issue, that was also pretty easy. I took a Jeep mirror from Steel Horse and simply swapped it on my truck. It goes on with four screws when I pull the doors off...it folds like three different ways for total adjustability and you can also pull it in for trail obstacles...I will try to get pics of it next time I have the doors off...
  17. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  18. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    In AZ you only need one mirror and it can be the inside rearview mirror.
  19. 73blazerUSMC
    73blazerUSMC Registered Member
    Jan 29, 2002
    43
    South CA
    im pretty shure in cali you have to have doors i have a friend that was runnig a bronco w/out doors with just mesh across the openings and got a ticket i told him it was cuz he was driving a POS ford all my chevy friends laughed but he just shot me a look
    -scott
  20. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    I really apreciate the pictures, anything anyone else has would be very helpful. If i do this i would be more than happy to document it and do a writeup for the site.
