how to remove ff14b axle shafts...
Discussion in 'The Garage' started by jekbrown, Aug 15, 2002.
  1. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    is this literally as simple as removing all the bolts on the "hub" of the axle and then sliding the shafts out? Are said bolts reverse thread or normal? I started to try to turn one... but didnt wanna use my big breaker bar unless I know I am turning em the right way. /forums/images/icons/wink.gif
    i am trying to do the weld-the-spiders mod... need the shafts out ASAP. thanks in advance!
    J
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes unbolt and slide out and the bolts turn normaly
  3. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    awesome and quick! thanks much man, back to the garage! /forums/images/icons/laugh.gif
    J
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no problem now get back to work /forums/images/icons/smile.gif you dont have much time left lol
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, too late for me to reply!! /forums/images/icons/laugh.gif
    Anyways, FYI, if anybody cares, those axle shaft bolts are 1/2" coarse thread, 1 1/4" long. /forums/images/icons/wink.gif /forums/images/icons/laugh.gif (Just had to throw some more info in! /forums/images/icons/wink.gif)
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    after you get the bolts out, if the axle shaft doesn't want to just slide out hit the center of it with a big hammer and it will.
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    With preferrably a mallet of some sort. /forums/images/icons/wink.gif I hate using a steel hammer on the shafts. Might make something weak or loose on the inside, such as the bearing nuts. /forums/images/icons/frown.gif
