how to remove front fenders?
Discussion in 'The Garage' started by pismorat, Feb 3, 2004.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    How difficult is it to remove the front fenders on our trucks? Do the outer fender and inner fender well come apart? /forums/images/graemlins/truck.gif
  2. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    takes about 20 minutes with no rust involved.
    about 8 bolts on the core support, all 1/2 "
    1 on lower fire wall, pita sometimes 9/16
    1 under hood by cowl...9/16
    1 in between door and fender 9/16
    I recomemned using a 1/4 drive rachet with a exstension, just opun the door and work through the crack.
    do front first, leave 1 bolt finger tight, and remove the top bolt last to keep from hurting paint or the fender while fiddleing with it.
    also remove light besel screws, and 1 bolt is at the top front of the core support hiding under the lip, and the lover valence should have a couple of them too.. /forums/images/graemlins/thumb.gif
    unbolt the hood and have a frind help, do hood, then inner fender then fender /forums/images/graemlins/peace.gif
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    not hard at all. just bolts. Which side? there are a bunch of bolts just inside the fender lip that holds the inner fender to outer fender.
