How to remove. Please dont flame!
Discussion in 'The Garage' started by Yohinan, Dec 18, 2005.
  1. Yohinan
    Yohinan 1/2 ton status
    May 21, 2003
    103
    San Diego
    This is my first time taking out an axle (the rear). I have this to the point I am trying to remove the c-clip but I can get it out for the life of me. Is there a special tool to do this? I am basically using two flat head screwdrivers and prying and lifting at the same time but it is not even budging. I am sure I am doing something wrong here but I am not sure what. The lock screw is out and also the pinion shaft. The locker is rotated so I have access to the c-clip but I just cant get it to come out. Can you clue me in as to what I am doing wrong? Thanks again. John
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    go to the wheel flange and push in on the axle shaft
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    Once the cross shaft is out you can push the axle shaft inwards, then the 'C' clip should just about fall out.
    Rene
  4. Yohinan
    May 21, 2003
    103
    San Diego
    Maybe that is my problem. I have pushed the axle in and the clip does not fall out. Does the thrust block have to come out also? The c clip stops when it hits the thrust block.
  5. resurrected_jimmy
    May 23, 2005
    2,241
    I was going to add something about what type of locker are you using so yes the thrust block needs to be removed
  6. Yohinan
    May 21, 2003
    103
    San Diego
    Any idea how to get the thrust block out? My manual did not state I had to take it out and it does not even show how to take it out. Thanks again for all the help and sorry for all the trouble. John
  7. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
  8. Yohinan
    May 21, 2003
    103
    San Diego
    What would I use that for? I already have a magnetic pickup tool. I am not trying to pick up a c clip I am trying to get it removed. I now know I need to remove the thrust block from the locker but I dont know how to do that. Thanks again. John
  9. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    What brand and model locker is it? That'd help a whole lot.
  10. Yohinan
    May 21, 2003
    103
    San Diego
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    Upload the pic to the CK5 photo gallery...you are a member and gallery space is part of what you pay for.
    http://coloradok5.com/photos/
    Rene
  12. Yohinan
    May 21, 2003
    103
    San Diego
  13. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    There ya go.
    Hopefully someone else can help you, I've only done the C-clip deal with Gov-Locks and open diff's.
    Rene
  14. resurrected_jimmy
    May 23, 2005
    2,241
    It looks like you have enough room an the right side to slide the c-clip out... but if it doesn't work, it doesn't work. with the cross shaft out the thrust block should slide out IRC, but it will only slide out one way so you may have to rotate the diff 180* Make sure the c-clips are seated fully and pull out on both shafts and the thrust block should drop out of the carrier, you may have to have some one rotate one of the shafts to help the block spit itself out
  15. Yohinan
    May 21, 2003
    103
    San Diego
    Well resurrected_jimmy I just walked back in and read your post. Good news is I got it out and then I see your post. Too funny. You were right though. I had to turn the locker 180* and it fell out the bottom where as before I was trying to pull it out. Thanks again guys for all your help. John
