How to remove pressed rocker studs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89Jimmy, Oct 16, 2000.
  1. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    I've got some pressed in studs that are worn from rockers rubbing on them. Anyone know how to pull them? Preferably without having to pull the heads. Thanks.
    John
    So Much to do, So LITTLE cash.
  2. bushwacker
    bushwacker Registered Member
    Sep 8, 2000
    58
    Orange County, Calif.
    Just went through that exercise. I removed the rocker nut,arm and cone washer, then placed a socket over the studleaving some threads exposed. Put a flat washer on the socket and then replace the nut and crank it down , it will slowly pull the stud out. If you run out of thread before the stud is free, you have to remove the socket and replace it with a longer one and repeat the process. Pain in the a$$, but no need to remove the head. Hope this helps. Bill
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Well bushwacker has it. You can also just stack washers, stack pivot balls, etc.
  4. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>Well what I want to know, is how do you get them back in? Or do you convert them to a screw in type? - Steve :)</font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
  5. Wheels
    Aug 18, 2000
    638
    I'd convert them to screw in studs. Makes em easier to work on later. To put press in's in, you'd need to remove the heads and use a press. I made a jig for this one time. I took a flat piece of 1/4" steel about 1" wide and drilled two holes the width of the studs apart. I pulled one stud, then used the other stud as a placement and bolted the jig in place. On the other hole I welded a nut in place that had the same threads as the screw in studs. I then run my tap in using the nut as a guide to keep the tap square. This is the key when tapping pressed in studs with screw in a type. It was a slow process but it worked. Now when I pull the heads, if they have pressed in studs, I put screw in studs in.
  6. Wheels
    Aug 18, 2000
    638
    Moved to front to respond to the other question same topic
