How to remove rag joint
Discussion in 'The Garage' started by MTBLAZER89, Dec 22, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    How do I get the rag joint off the splined part of the input shaft? I got the bolt loose...do I have to remove it all the way? Do II have to use a special puller, or just tap it off? Thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, you need to remove the bolt all the way. then i use a pry bar to get it off the splines, prying one side then the other
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    cool thanks:xmas:
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I didn't have to pull the bolt out all the way. :confused:
  5. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    Use the "pickle fork!"
    You can use a "pickle fork" tie-rod remover tool to remove it,after taking the bolt out--when the rag joint on my 74 K20 failed(and I saw my life pass before my eyes)I had to use a torch to cut that 12 point bolt off--no wrench or socket known to mankind would have removed it,it was rotted to death..still cant beleive I didnt fry the seals in the steering box--must be because it was about 20 degrees and snowing out when it happenned!!...Hope I never have that experience again!:blush: --now I must fix the tilt steering colum in my 79C10,the U-joints in it are loose--I have nightmares of the steering wheel coming off with half the colum still attached---.:crazy:
