how to remove really bad caked road tar and crud ! ?
Discussion in 'The Garage' started by R72K5, Aug 10, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    lots of the stuff, REALLY bad, tons of it, horrible,
    anyone know ? soak with WD 40 first ?
    no ?
    any ideas ?
    on vehicle w/ factory laquer paint
    thanks
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Try a claybar, that always works for me
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    WD40 has worked for me in the past...
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    One summer when I first joined the military I worked part time at a full service carwash. When we detailed cars we used WD-40 to get the road tar off and other stuff like those smashed bugs that embed themselves into the body. We would soak it on there and scrub it off after a few minutes and run it through the car wash. If there was still some on there we would repeat the process.
    We never had any complaints of damage to paint???
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    WD-40, kerosene, goof off, mineral spirits, any mild solvent will work....
    stronger solvents work too and are good for other hard surfaces.. just need to be careful with painted surfaces and do a test spot with lacquer thinner, etc...
    what year? are you sure its lacquer?
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    They make bug&tar remover available at most any autoparts store, kmart, etc...
    I used to work at a detail shop, we used a commecially available bug&tar remover. WD40 is a little harsh for factory paint, contious usage in the same area will damage the paint, if your not careful.
  7. diesel4me
    Jul 24, 2003
    17,561
    941
    Massachussetts
    "Bug And Tar" remover!!
    In my experience,"Bug And Tar" remover is mostly diesel fuel or kerosene and mineral spirits sold in pint cans for the same price as a gallon of diesel fuel!...I dont have any prize winning paint jobs,so I just use diesel fuel!..I doubt it would hurt the paint unless you leave it on for hours..
    I usually leave the tar on!--its a good rust deterrent!..free undercoating! :laugh: :crazy:
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes its laquer it says laquer on the SPID lable on the trunk deck its the 84 impala
    it is 22U dark blue
    its caked in road tar and rock, bad,..,
    i have some kerosen, like 5 gallons of it, humm..
    i think its too much caked on for WD40..
    the roads get so hot that the road surface lifts off onto cars here, and the roads buckle and such., and IL is too broke to fix any of it right, then winter comes along and freezes and expands cracks and make pot holes and just rips the roads up even more than the summer heat does, then they toss tons of loose chiprock on the roads in summer too, so that you get to have busted lights and BB hole glass all the time.,
    street/highway departments and well the entire state isnt all that bright.. but then since the city/county street departments are hardly funded..(seems less and less each year)..
    just another one of billions of those little things that will evnetually help start civil war II
    heh,..
    thanks
  9. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    try the kerosene... let it soak, wet it again, etc.. lots of elbow grease...
