How to remove shifter from a 465?
Discussion in 'The Garage' started by beatuptruck, Dec 3, 2006.
  1. beatuptruck
    beatuptruck Registered Member
    Nov 24, 2004
    6
    Alberta
    Hi, Im trying to remove my transmition so I can change the clutch in my 81 GMC 3/4 ton 4x4, but I can't figure out how to take the shifter out.
    I tried pressing down on the slotted collar plate and rotating counter clockwise, but it will only turn about 45 degrees then it stops.
    What am I missing here? Do I need to remove the entire top cover of the tranny?
    Any help would be appreciated. Thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Put the tranny in nuetral the do as you said and it should come out. It might have a bunch of crap built up around it and not allowing it to pull out so clean it good first.
  3. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    If you got it turned 45 degrees it should just be to lift the whole thing up:dunno:
  4. Roland_Jenkins
    Roland_Jenkins Registered Member
    Apr 14, 2006
    58
    Newport Washington
    I welded a piece of rebar across the shifter to use as a handle.
  5. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    just for a handle to pull the shifter out of the tranny, or just for a handle for shifting?
  6. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    did you pop the two pins on the side?
    Some pics
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    You do not need to remove those pins. Those pins are what the collar twists on to remove the shifter.
  8. NoReGrEtS
    Nov 7, 2005
    848
    your right
  9. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Push down on the round base of the shifter and turn, assembly pops out. Its always worked for me.
  10. beatuptruck
    Nov 24, 2004
    6
    Alberta
    Thanks guys, I just gave it a good yank and it popped right out.
