how to removed the wiper arms?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Mar 21, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I'm assuming you just pull them straight off, but they aren't coming. I just wanted to verify, or see if anybody had any suggestions before I got down and dirty with them.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Are you talking about removing the entire linkage? If so, you need to disconnect them from the wiper arm motor. I believe a 10mm socket and a 1/4" racthet and extension should do the trick.
    Don't remove the nuts all the way, just make them both loose.
    -- Mike
  3. tRustyK5
    Jul 23, 2000
    36,164
    1,360
    E-town baby!
    There is a little clip thing on the underside that releases the arm from the splined end. Believe it or not GM makes a special tool for wiper arm removal...
    I bent the tip of an old flat blade screwdriver which seems to work OK as long as the arm isn't 'frozen' onto the splined end.
    Rene
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    When I painted my K5 couple years ago I pulled the arms off.. They were stuck. I just used a flat tip screw driver and worked around the base of the arm that mounts to the splined ends.Took some energy,and some pulling to get them off...
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks guys - I'll have to try that in the morning Rene, or go see if the local bodyshop will lend me their wiper removal tool.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    With the right tool, they will usually yank right off. Lisle makes one that's pretty cheap. Most parts stores carry 'em.
