How to Replace the King Pins and Bushings in 1986 3/4 GMC 4x4 PU???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Dave1, Jan 7, 2003.
  1. Dave1
    Dave1 Registered Member
    Jan 4, 2002
    82
    Winter Springs, (Central) Florida
    I blocked the front end of my 1986 GMC 3/4 4x4 pick up truck in the drive way last night and tore down the front hubs/spindle to replace wheel bearings, spindle bearings, seals, axle u-joints, etc. Once disassembled I noticed the king pins and bushings are loose. Not having ever replaced them before I need some "how to" advise. Is this something I can do myself at home with regular hand tools? What is the step by step procedure for replacing them?? Thanks, Dave1 davisalf@aol.com
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> An 86 3/4 ton should have a 10 bolt, which has ball joints, not king pins. You can do this in your driveway, it's not that difficult of a job. You need a ball joint press and basic hand tools, but since you've already torn apart the whole front end, just the ball joint press will do it.</font color>
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    A 3/4 ton with king pins??
    I thought the 3/4's all had ball joints and only the dana 60 had the king pins?
    To change the ball joints you need a balljoint press, or just strip the axle down and out of the truck and run to a near by machine shop. they can pop the old ones out and install the new ones in no time.
    To have an alignment shop to do this would be $500 ( I know I called,LOL)
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    $500? Wow, and i bet some people pay it.
    Come over to my house and I'll do it for $250.
    /forums/images/graemlins/smile.gif
    -- Mike
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I said screw that and went and bought a whole complete running 77 for $1100, got my front, rear, tranny and tcase out of it /forums/images/graemlins/laugh.gif sold the motor out it and it gave me a starting point for the Willy's
