how to secure an ammo can
Discussion in 'The Garage' started by pismorat, Feb 20, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    I have a large ammo can that I want to mount in the back of my pickup for holding spare parts. What would be the best way to secure it and keep it from bouncing around? My old idea did not work and my first can was scraped. It also has to be locked since it is outside and can be tampered with. :truck:
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Rivet or weld a lock hasp to the can so that the loop of the hasp sticks through the lid's handle. Throw a padlock through it and voila!
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    if you dont want it to bounce around screw/bolt it to the bed from the inside. wont go noware
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    I did that and it has worked great....
  5. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    heres mine...
    basically, I just put it where I wanted it, drilled 4 holes through the can/body and then ran some bolts from the bottom up into the can and put big fender washers and locking nuts on them. To make the can lock, I used 2 u-bolts. Drilled 2 holes in each side of the can where the lock-down handle thing is and run a padlock through the u-bolts and you have water proof, lockable storage. Could it be removed by force? probably, but not without making enough noise that you risk the pist off owner coming outside with his H&K USP. ;) I herculined my ammo cans after I primed/painted them just for extra weather resistance. They work well and no matter how much I am bouncing around on the trail, there is no risk of a big wrench flying out and hitting me in the head. :D
    j
  6. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I think I remember seeing somewhere someone bolting a big ammo can in for a center console, and then making a smaller container on the lid, for little stuff. I think there were some cupholders involved somewhere too.
    All this thinking is hurting my head.:doah:
