How to secure your highlift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by outsider223, Mar 17, 2003.
  1. outsider223
    outsider223 1/2 ton status
    Mar 17, 2002
    122
    Green Bay, WI
    I'm curious how everyone stores their highlift. Right now mine is sitting in the back of my blazer making a bunch of noise and sliding all around. I'm also wondering how people store parts and tools in their vehicles? I have one big plastic storage, but I'm planning on making something more permenent.
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've got a "V" bar in my main hoop, it comes down and mounts in the center behind the front seats. About 1' off the floor I welded on some mounts. The mounts are made from 1.5 x 0.187 square tube and 1/2 bolts with wing-nuts. Cut two pieces of square tube about 1.5" long and drill a 1/2" hole in the center of one side. Take (2) 2" long 1/2" bolts and cut the heads off. Stick them in the holes in the square tubing and weld from the inside so there is no bead on the outside. These will fit perfectly inside the channel of the "I" beam of the jack with the bolts going through holes. Stick them in place on the jack bar so that they line up with your chosen mounting surface and secure them with wing nuts to guarantee alignment. Tack them to the mounting surface, weld them in solid, and you have a nice mount that will not rattle and holds the jack securely...
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    There are some threaded holes in the my body in the back. I welded a handle to a bolt, to make a T. The jack fit between the wheel wells, I put the base againts the one wheel well and the bolt through a hole and screwed it down, it works, doesnt go anywhere.
  4. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
  6. jekbrown
    May 19, 2001
    45,029
    361
    Vancouver, WA, USA
    purdy simple... 2 big bolts, run em through whatever part of the body of ur rig (or bumper) that u want, torque em down... then put the high lift on top of the nuts using the holes in the highlift... then put wingnuts on top of the bolt that is sticking through the highlift and you're set. not sure if that made sense... but it works, its cheap, and its easy. /forums/images/graemlins/smile.gif
    j
  7. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i mounted mine on the lip of my bed side. drilled 2 holes put bolts and nuts in them and then set my hi-lift over the bolts and tightened it down with nuts. that way it's secured inside, out of the way, and still easy to get to. /forums/images/graemlins/laugh.gif
  8. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I have a flat mount spare tire holder www.fabtechmotorsports.com/html/misc.html and my hilift is clamped down to the floor with the tire. Pretty much I lay down the hilift near the tailgate, lay the 35'' on top of that and crank down on the "handle bars", I can't get the jack to budge without loosening the tire holder /forums/images/graemlins/thumb.gif.
  9. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I welded 2 carriage bolts to the roll bar, slid my HiLift over them and put 2 nuts/washers on them. Secure, and it only cost about a buck.
  10. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    This how I have it mounted on the '80: http://tellicok5.rockcrawler.com/photo3.html I got the mounts free when I bought the jack and steel was free (scrap) /forums/images/graemlins/grin.gif I used to have drawings up but they got dumped somewhere along the way.
    When I first got into this it was chained to tiedowns in the floor, near the tailgate.
    The one in the '73 is chained to the rollbar. It's kind of a pain. Its temp, but I had to do something, because when I bought it had some mounts like the '80 that were screwd into the inner bed side w/ drywall screws!
  11. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    It must suck to not be able to use your review mirror. I don't even like running my truck with the tailgate on because the puddle jumpers like to hide underneath my rear bumper. I can't imagine intentionally mounting a tire where I want to look.
  12. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    LOL! That's not my truck. I just linked the larger version of the pic form the previous post to help out. Mine is mounted sorta like that, but to the roll bar behind the front seats. And, not only do I not have a tail gate, I don't have bed sides, a top, fenders, ... /forums/images/graemlins/rotfl.gif
  14. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
  15. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    Those are all good ideas. Now just to find something that will work for me. Has anyone mounted these to a bumper or roofrack? I've thought I saw one mounted on a front bumper once.
  16. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Mark's got his mounted to his roofrack on his Pathfinder. It's held on with wingnuts.
    http://www.sos.mtu.edu/4x4/images/markl1.jpg
    I'd avoid putting them on a bumper if it were me. They'd spend a lot of time covered with mud if they were on a bumper of my truck. Not to mention I might peel it off on a tree.
    Can you mount it to your bedside on the inside? I plan on putting one there someday. If you get real crazy you can stick plates up from the backside (between inner and outer skin) to make it stronger. This is what I plan on doing. If I ever save enough money for one. I keep buying wheels and tires and other junk.
  17. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    Yep, thats where I saw one mounted to a top basket. I was thinking of mounting the highlift under the bed rail. I might use some of the holes for the top and attach something to the side.
    Do you guys still meet on Thursdays in Fisher?
  18. Storm Trooper
    Nov 24, 2000
    4,640
    Here is how I mounted mine. Highlift
    Works good for holding a come-along also.
  19. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Yeap, Fisher on Thursdays at 7pm. Usually it's in 326 now but they forgot about us when scheduling rooms so sometimes we have to move around.
    Someone else used to have one mounted to their rack that was associated with the fourwheelers but never came to meetings but it's not on there anymore. I think someone might have stolen it.
  20. outsider223
    Mar 17, 2002
    122
    Green Bay, WI
    I'll have to come to a meeting, but I won't be able to get to one until after the weekend of April 5. I'm working on our steel bridge project and the competition is that weekend. I'll be there after that. Do you guys have an email list?
