How to shorten hardtop? Cybrfire
Discussion in 'The Garage' started by BozoWise, Sep 15, 2005.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Can anyone provide a writeup or how to on how they shortened there hardtop. I really like the look on Cybrfires with the narrow.
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I would think .. cutting, and lots -n- lots of fiberglass work.
    Or, you could get a "sleeper" and tie it in. :dunno:
    Depends on what you want to end up with as far as a top goes.
  3. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    I basically decided how much top I wanted to end up with, Basically room for a second seat.
    Then I cut the center section out leaving enough on the ends to reattach together to come up with the right length of top.
    Once cut, I had to cut the rear portion in half the other direction to make it fit the bed rails.
    Now take all three pieces and grind them hard, not just scuff but Grind. Make the edges ugly and lower than the rest of the top, kinda like "v-ing" for a weld. I also drilled a bunch of 1/4" holes near the edge to give the new glass something to grab hold of.
    I used aluminum strips screwed to the top to set the edges level with each other and hold things in place.
    Glass as much as you can without covering the aluminum strips and let that set.
    Remove the aluminum strips and finish glassing.
    Now, since I made the edges lower by grinding I was able to go back and smooth them off without removing all the glass.
    Also glass the inside and whatever window hole you have left.
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Thanks bud that is what I needed to know. I wasn't sure if you just cut it once from drivers side to passenger or twice. That might be on my upcoming list of projects.
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Sweet! Thanks for the info, Kert. I'm looking at doing that as well, only I plan to do mine longer. I need more room for the dog and/or a passenger. It'll be wierd with a pickup but I can make it work
    Mike
  6. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    I do have a fair amount of pictures of the process as well. If you'd like to see them I could email them.
  7. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    :hack: :hack: :hack:
    looks good, Are you still going to beable to remove it?
  8. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    oh Kert, You need to chrome plate that hugh diy4x plate, some serious bling :pimp: :pimp:
  9. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    That would be awesome!!
    mikenospam@redlineenterprises.com
    remove the 'nospam'
  10. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
  11. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    That's the sign that hangs in the front window of my shop. Chrome would be acceptable there wouldn't it??
    Yep, the top is still removable. I'll probably be ditching it sometime early next year and having a canvas top made.
  12. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    I will dig up the picture CD and get some emailing done tonight. :wink1:
  13. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Did you have that thing in a parade or something Kert? Looks like a great way to promote the business, if us Iowa guys ever have all our trucks running at the same time, itll be one helluva good time.
  14. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    Yep, in the town parade last month. Next year I may have to put the bus in the parade! :haha:
  15. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    hell i woulda put it in this year :bow:
  16. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    I strated on mine today. I am going to attempt to narrow mine from the top back. I only sectioned mine in one spot. It bolts up with 3 of the factory bolts.
    Instead of double posting I will put the writeup in my buidup post linked in my signature along with more pictures in my photo album.
  17. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I like it...I bet you could even get a glass shop to cut you a window if you can get the channel close enough. That would be P.I.M.P. :D
  18. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    I think I am going to do a metal frame with racing nets. No need for glass since I will be running DIY tube doors.
    I am huffing fiberglass resin as we speak :rolleyes:
  19. cybrfire
    Dec 15, 2002
    15,143
    575
    Iowa
    I had the cd out just the other day with the photos. Still looking for it.
    :doah:
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    too bad you're not closer Mike, i've got a sleeper cab that came off of my C20. that might be a better start for you than a K5 top would be.
