how to---- steering wheel removal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chebywanna, May 1, 2003.
  1. chebywanna
    chebywanna 1/2 ton status
    Apr 20, 2003
    277
    streamwood, (chicago)
    i got the center bolt off but the steering wheel won't come off, why, is it pressed on there? i thought they just slid on. (90 full size p/u)
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    you should need a steering wheel puller i think. but the more experienced guys can prove me wrong,
  3. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    You do want a steering wheel puller and a lock plate compressor if you plan on going beyond the steering wheel.
  4. chebywanna
    Apr 20, 2003
    277
    oh well forget the steering wheel than, i got started on stripping it too late.
    and i got to say, DANG!! quick replies! i..... like it /forums/images/graemlins/thumb.gif
  5. alesko
    alesko Registered Member
    Apr 27, 2003
    47
    sw pennsylvania
    Steering wheel pullers are inexpensive and can be bought at any parts store.
    However you can try this, screw nut back on until its flush with the bolt, get a BFH, wrap one arm around the wheel, pull it toward you and with the other hand take the BFH and wack the nut a few times. Two people would make this easier.
    WARNING; I've done this a few times and it worked, but the risk of damaging something is great.
    If you are not in a hurry, get a puller and make your life easy.
  6. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    You can also try just banging on the back of the steering wheel towards you alternately one side to the other. The danger is the wheel could come off suddently and smack you in the head, mouth, nose etc. Personal experience. /forums/images/graemlins/tongue.gif With a little persistance this method has always worked for me. /forums/images/graemlins/thumb.gif
  7. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You can rent pullers at Autozone for free. I highly recommend it since I've taken mine off without the puller or the compressor and you can do it just make sure to eat your wheaties, spinach etc before hand /forums/images/graemlins/wink.gif
