how to stop the sway and stiffen the ride?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BPS, May 2, 2003.
  1. BPS
    BPS Registered Member
    Mar 24, 2001
    28
    Sooke, BC, Canada
    I have a '90 K5 with new rancho 5000 shocks all round, new wheels and the roadmaster active suspension kit http://www.activesuspension.com/
    I'm finding that the truck is still very bouncy and really "floats" when I drive on a twisty turney road.
    AFAIK - there are no sway bars on the vehicles - is this normal? I don't even see where te would bolt on to!
    How can I stiffen up the ride??? I'm tired of turning left and have the body want to tilt to the right.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> They did come with a front sway bar from the factory, if you don't have one then someone removed it. the truck is never going to handle like it's on rails though; it is, after all, a truck. </font>
  3. BPS
    Mar 24, 2001
    28
    Sooke, BC, Canada
    /forums/images/graemlins/smile.gif I know it's never going to be really tight - I just happened to be behind it today while someone else was driving and it sure bounces around a LOT more than other trucks especially considering it have new(ish) shocks.
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    POLY BODY BUSHINGS /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
    100% increase in drive-ablitiy
  5. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    It should definitely have a front sway bar on the front axle where the spring perches are. I hated the unstable ride of my 88 so I bought 2" spacers for the rear widening the rear axle stance 4". That made a huge difference. Check all of your steering linkage and ball joints. The slightest amount of play makes them handle like sh!t. I also added the rear anti-sway bar. Another huge improvement. A tight steering box and good steering stabilizer also helps. Finally check your alignment. These things have a tendency to oversteer and sway. Mine is like a new truck now. /forums/images/graemlins/k5.gif
  6. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    If you don't do much wheeling re-install the swaybar. I have been driving without mine for a year now and I am not putting it back on.
  7. Grim-Reaper
    7,385
    Atlanta
    Just noticed that your sig says you have a camper on it. I'm not positive but I think Chalets came with a rear sway to help with the raised CG. Helwig makes a sway that will work on these trucks. That might be your answer.
    THe stock 79 I just sold handled great. For what it was I thought it was above average. My 2wd Burb wallows in compairison but the shock are shot. See if the Bilsteins I just orderd fix that.
  8. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    get an anti-sway bar from a ck5er who doesnt need theirs and install Rancho HD front springs. Your suspension will never flex again.
    j
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    yup. Put sway bars front and rear.
    I have them on mine. I disconnect them if I am going to do any serious wheeling. But reconect them when on the road. I hate the way it handles without the sway bar. Its like driving around a beached whale.
    I drive fast and I tow quite a bit so I really like sway bars. /forums/images/graemlins/thumb.gif
    Check this site out:helpersprings.com
    They should have what you need to fix things up.
    You should be able to pick up the front sway bar cheap from a junkyard. just put in some poly bushings and yur good to go.
  10. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    My truck used to handle like that too, then I put Bilstein mono tubes all around and added a Hellwig rear sway bar. 500% increase in handling and drivability. And I've got a set of Poly body mounts and suspension bushings waiting to go on. If you're not doing heavy wheeling, add the rear sway bar. Probably the best non-engine related mod i've done.
  11. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    gotta link to the bilstien mono tubes? how much did you spend of them? thanks,
    jason
  12. BlazinRojo
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    honestly, the bilsteins were a gift from my dad, so I'm not really sure how much they ran. I'll talk to him about it next chance I get.
