How to straighten frame????
Discussion in 'The Garage' started by BlazerGuy, Feb 6, 2004.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Awhile back my towhook got caught on a rock and bent the frame /forums/images/graemlins/doah.gif, as you can see. How can I straighten it?? Or is it best left up to a shop? don't worry about the spring hanger, I can get another one of those. Keep in mind I don't have a welder(I do have a torch though). /forums/images/graemlins/bow.gif
    and
    Oh and keep your "Those towhooks and the way they're mounted sucks" comments to yourself...they're the PO's doing and I'm trying to get rid of them... /forums/images/graemlins/shame.gif /forums/images/graemlins/grin.gif
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'd say if the frame (vertical section is not bent) just the bottom... get a huge ass plumbers wrench and put on there and bend that area back down, then drill a hole in the front bumper and piece of 2"x1" steel about 16" long and drill a bunch of holes in it and mount it to the frame and put a clevis on the front /forums/images/graemlins/waytogo.gif
    ^ the other little piece of steel is like 1/8-3/16" same holes and sandwich the frame /forums/images/graemlins/wink.gif
  3. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Sounds like a good idea.... /forums/images/graemlins/thinking.gif
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    i say get a big floorjack under the spring hanger... just tall enough to keep the suspension from compressing too far..put a piece of plywood under the jackstand, run a come-along cable under the plywood, under the tire and back to the t-case xmember, and come along the frame straight?? but use a towel between the cable and tire.. /forums/images/graemlins/dunno.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I say torch the tow hook off and leave it. That part being bent isn't hurting anything.
  6. Confedneck
    Nov 1, 2002
    5,236
    nah, but the spring hanger being bent possibly could be..
  7. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I usually have the hook off since it's useless but I put it on in the pic so y'all can see the angle better(the hook use to be straight). I haven't had any problems with it yet but I might in the future since I plan on relocating the spring hanger foward to accomodate 52" springs. I think I'm gonna get it as straight as possible with the forkin huge wrench idea and slap some D-shackles on da beotch! /forums/images/graemlins/peace.gif Hell, it'll even improve the approach angle... /forums/images/graemlins/woot.gif
  8. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I assume I should use a 2"x1" solid piece of steel??? Thanks /forums/images/graemlins/ears.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Heat it and beat it, it'll go back. /forums/images/graemlins/smile.gif
