how to swap to a hydraulic setup?
Discussion in 'The Garage' started by kickinasphalt383, May 5, 2002.
  1. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    i have a mechanical linkage for the clutch on my truck... it sucks!! how would i go about swapping to hydraulic WITHOUT swapping the bellhousing or fork?
    i know Wilwood makes that slave cylinder... but what else would i need to make that work? are there any easier routes i could take?
    thanks
  2. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    I've done a swap from linkage clutch to hydraulic. You need to get the right hydraulic parts to make it work properly.
    Do a search... there was a post on here last week where I pretty much detailed what I had to do on my truck.
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Not sure how you do this without the right bellhousing tho.
  4. kickinasphalt383
    Dec 6, 2001
    224
    Michigan
    i was under the impression that i could install a slave cylinder that would pull the original (manual linkage fork)? without having to swap the bellhousing or fork?
  5. Quack_Addict
    Feb 24, 2002
    119
    Michigan
    I'm not saying it isn't possible, but that would be interesting...
  6. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I am pretty sure some one has done that, I recall seeing pictures posted once.
  7. kickinasphalt383
    Dec 6, 2001
    224
    Michigan
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    normal hydro pedals and master with a custom line.
    it will never look as good as gm hydro bellhousing
  9. beej.johnson
    beej.johnson Newbie
    Mar 7, 2009
    4
    Springfield, OR
    You would just need to make a custom bracket that mounts on the PTO bolts on the 11 and 10 oclock bolts if you are looking at the plate from the drivers side. Unless you have the van bell housing and it is on the passenger side. At least this is what a friend of mine did with his CJ7 swapping in a SM465 to his Jeep.
  10. jt512
    jt512 1/2 ton status Premium Member GMOTM Winner
    Oct 19, 2006
    4,519
    11
    Maryland
    Hopefully he figured out his problem, since the thread is 7 years old :D
  11. beej.johnson
    beej.johnson Newbie
    Mar 7, 2009
    4
    Springfield, OR
    oops, well at least whoever looks at this in the future they can have that info for their use hopefully. :)
  12. K10 KRAWLER
    K10 KRAWLER 1/2 ton status
    Sep 16, 2008
    399
    Carstairs, Alberta, Canada
    :doah::haha:
