How to take off and replace 14 bolt yoke
Discussion in 'The Garage' started by BIGRED74K20, Jun 26, 2006.
  1. BIGRED74K20
    BIGRED74K20 Registered Member
    May 23, 2005
    82
    23
    Northwest
    i just bought highangle driveline new 14 bolt yoke with u-bolts. i was wondering if it was a basic job to take off and put back on. if so school me
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    nope
    well it is simple but you neet to reset the pinion bearing preload
    to do it right you need a new pinion nut, and a new crush sleeve.
    the eaisest way to do it, unless you have all the tools, is to take the center chunk out and take it to a gear shop, just be careful to not loose the shims on the center chunk.
  3. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Where are the shims on a 14boltFF?
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    In between the pinion housing and the axle housing to set pinion depth.
  5. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    right, It sounded like he was talking about shims for the carrier.
    oh nevermind it makes sense after re-reading it.
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    To do it right you need a new crush sleeve and a pinion nut but I imagine you can probably get away with the same crush sleeve thats in there. I would check the pinion bearing preload on the pinion assembly (make sure to do this while the pinion assembly is out of the housing). Then put on the new yoke with a new nut and make sure you have the same preload as before. You will need a dial type inch pound torque wrench. Atleast that would save the hassle of pressing out the bearing and putting on a crush sleeve and recrushing it. But if I was doing it, I would recommend doing it the right way. Which will require a press to press on the old bearing back onto the pinion. I personally like to start the crush sleeve with the press then tighten it up to spec with a big breaker bar. If none of this makes sense maybe you should just take it to a good gear shop and let them do it right. Those pinions spin terribly fast and if the bearing preload is too loose or tight you will have big problems on your hands.
