How to take off steering wheel?
Discussion in 'The Garage' started by 85mudblazin, Jun 24, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am wanting to put on a grant steering wheel and I cant figure out how to take off the stock steering wheel, I took off the horn stuff and that one large nut and it still wouldnt come off, need help!!!
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You gonna hafta sacrafice a lamb to the steering wheel gods....then your gonna hafta get a steering wheel puller... /forums/images/graemlins/waytogo.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    hack it off, and by a after market one /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Do they have the steering wheel puller at like autozone??
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yea you can rent them here in N.C. and when ya return them you get ALL /forums/images/graemlins/thumb.gifyour money back.
  6. Curtis2kul
    Curtis2kul Registered Member
    Oct 15, 2002
    62
    Winston-Salem, North Carolina, United States
    Yea, in winston( North carolina) we can rent and get all our money back to!
  7. berndogg
    berndogg Registered Member
    May 21, 2004
    7
    northern Vermont
    The most basic tools make life so much more grand. I bought a puller for under 20 bucks and youd be surprised how much it would get used after you own it.
  8. branrat
    branrat Registered Member
    Jun 22, 2004
    14
    Sumner, WA
    Tighten the steering wheel nut down snug then tighten it REAL good. This will break the steering wheel loose a bit. Then remove the nut & use the puller
  9. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Yeah, because all your buddies want to use it! /forums/images/graemlins/whistling.gif
  10. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I just got my new steering wheel and a steering wheel puller and I took off all the horn stuff and put the puller on and started cranking down then snap and I was like WTF then I looked and stupid me forgot to take off the main nut that holds the wheel on, so I tried to get the broken piece out but no luck so I am just gonna get some new bolts and use the other holes in the puller, all well maybe ill slow down next time. /forums/images/graemlins/doah.gif
  11. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    Loosen the big nut. Screw the nut up so that it is even with the end of the bolt.
    Bring your knees up to the base of the steering wheel. Put your toes on the floor and push as hard as you can on the wheel. Now grab the top of the wheel with one hand and pull towards you as hard as you can.
    Now give that nut a few whacks with a big @#$%'n hammer.
    The wheel should pop off. Don't worry the nut won't let it come off far enough to break your teeth.
    Use some discression here as you can collapse the column or just ruin the bolt or nut.
    If it seems that you are damaging something or you are just putting too much effort into the project it will be time to buy another puller.
