How to take out windshiled wiper and headlight switches
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by TheBlazerKid, Feb 24, 2003.
  1. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I need to get the switches out to swap in my new "custom" dash. how do the controls come out, not the whole assembly just the push pul and turny thigns. /forums/images/graemlins/1zhelp.gif
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I think you just have to turn the nut holding them to the dash... might need a small allen wrench to take the knob off...
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Headlight switch - Disconnect battery, pull switch to "on" position, reach up behind dash and push in the button that is on top of the switch, this allows you to pull the knob/shaft out of the switch. The lights will stay on, which is why you want to disconnect the battery.
    Wiper switch knob is held on by a set screw in the side of the knob. Requires a small allen wrench to loosen set-screw, and the knob comes off.
    Both switches are then held in by hex nuts from the bezel side - it is obvoius once you get the knobs off.
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I usually just pull the harness connnection from the headlight switch in order to remove the headlight switch knob...
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You still have to push the button on the switch to pull The shaft out. /forums/images/graemlins/thumb.gif
