How to take SPIDER GEARS out of 10bolt rear ??? mini spool goin in
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ColAdo82K5, May 3, 2002.
  1. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    Stock 82 10 bolt, 28 spline, how do you take the spiders out ? Take c-clips out, pull shafts out, WHat next ? how do you remove that major center shaft in thecenter of the carrier ? don't the spiders basically fall out after that shaft is taken out.(this is an open carrier) With some of the mini spools, you need c-clip eliminators, but with this one you don't have to suppposedlly. we will find out and i'll report back for all those in need of traction on a shoe-string budget.
    Blake
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    One end of the pinion shaft that the spider gears ride on has a bolt that holds it into the carrier. It's a long bolt, with a tiny head. I think a 5/16's wrench fits it. Remove that bolt and the pin will slide right out. /forums/images/icons/cool.gif
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    As far as I have been able to find out you only need c-clip eliminators(which always leak) for the full spools, the mini spool should fit right in there without any other modifications.
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Ask desertdualler. He advises against this setup.
