how to tell gear ratio's? PLZ help quick
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NITRO, Jun 25, 2002.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    how to tell gear ratio\'s? PLZ help quick
    how can i tell if my 12 bolt rear is 3.73? what should the #'s b on the ring gear? thanx
    NITRO
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: how to tell gear ratio\'s? PLZ help quick
    <font color="green"> Gears generally have the tooth counts for the ring and pinion stamped on the edge of the ring gear. If when you divide the larger number into the smaller one, you get 3.73, then it's 3.73. </font color>
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Should be 41 &amp; 11. Atleast thats what's stamped into my 14b with 3.73's. /forums/images/icons/grin.gif /forums/images/icons/cool.gif /forums/images/icons/smile.gif /forums/images/icons/wink.gif
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    The best way is to pop the cover and count the teeth or look for the stamping on the ring gear. The other way is to jack up the back of the truck and put some marks on your tires and driveshaft and spin them several revolutions, counting driveshaft and wheel turns. Then divide driveshaft revs/wheel revs and look for the closest standard ratio (because your counting process wasn't perfect).
