How to tell how much lift a vehicle has?
Discussion in 'The Garage' started by cj7jeep81, Jan 23, 2004.
  1. cj7jeep81
    cj7jeep81 1/2 ton status
    Feb 17, 2003
    110
    Indiana
    I bought a '79 K20 yesterday, and am trying to figure out how much lift it has. The previous owner bought it with the lift, and doesn't know. It clears 40" gumbo mudders (roughly 36"-37" actual height), and doesn't have a body lift or fender trimming.
    There aren't any labels or part numbers on the springs, but there are part numbers on the shocks, and I don't know the manufacturer of the lift.
    Anyone have any ideas on how I can figure this out?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you have anyone in town with a stock blazer/suburban/p/u, measure their truck from top of inner fenderwell to top of axle,then measure your. Should give you a rough idea as too how much lift you got. Deduct a little bit to compensate for springs sagging depending on age pf springs. Hope that helps. I'd measure mine for you but I can't leave work right now. /forums/images/graemlins/k5.gif
  3. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    I have a '78 stock K10 that I checked, but wasn't sure if that would be accurate. I'll check that again tonight.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    It's probably a 12 inch kit if it clears without cutting. Big lifts are hard to tell sometimes but shorter lifts are very easy to identify.
  5. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    I measured my two trucks at lunch. Stock K10 ~ 12.5", lifted K20 ~ 22". I'm guessing 10", unless my old springs are sagging about 2.5".
  6. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    not a scientific method, but you could snap a pic of the rig and post it, Im sure peeps who have a similar configuration would recognize it with some degree of accuracy.
    j
  7. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    I have a pic, but nowhere to host it.
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Why dont you just measure the arc of the springs? Put a yard stick, or equalivent, from one end of the spring to the other, and measure from the bottom of the pack to the stick, that should give you a better idea.
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If search was working I would give you a link to a post made by Stephen Watson on the subject. It has a bunch of measurements from alot of different trucks. When it gets back to working you should try and find it and post up your lif measurements.
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    j
    Good idea! We have pretty sharp eyes. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    ok, here's his truck... [​IMG]
  13. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    im guessing 10" does it have springs in the rear too... If its got blocks just measure the block /forums/images/graemlins/eek.gif
    BTW looksl like a pretty nice truck /forums/images/graemlins/thumb.gif
  14. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Nice ride
  15. Chase
    Chase Registered Member
    Oct 23, 2001
    18
    I amn pretty sure thats a ten because with 12" you can clear 42" because thats my buddies old setup.Looks good what drivetrain and axels are under it?
  16. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    yeppers, I'm thinkin' 10" also...
    j
  17. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i vote for 10" too, nice truck /forums/images/graemlins/thumb.gif
  18. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    Thanks for all the replies. It probably is a 10". I am going to do the yardstick measuring tomorrow.
    Its a K20, with a 14 bolt in the rear, and I'm not sure on the front. I'll have to get pics of a 10 bolt and a 44 and compare them.
    The truck is in surprisingly good shape. Couple spots of rust, but not too bad. The frame is nearly perfect. It has blocks in the rear, but not too tall (I didn't measure, but they looked to be about 4"). I figure it was a pretty good deal for $1,350.
  19. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
  20. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I think you got a hell of a deal. /forums/images/graemlins/grin.gif
