how to tell if a 205 has been rebuilt...
Discussion in 'The Garage' started by jekbrown, Jan 14, 2006.
  1. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    going to look at a ford np205 tommorow. Guy said it was "completely" rebuilt (I asked for specifics, if the bearings were replaced etc). Question is, if it was a couple of thousand miles, how will I be able to tell? He has two... one with an unknown history, one supposedly rebuilt. Will there be "slop" in the input or output yokes or anything if the bearings are old/crusty? Any indicators that would be a sure giveaway?
    j
  2. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    also, what parts are swap-able between the chevy and ford cases? I want them for their inputs/outputs and rebuild parts (if it is rebuilt!) anything else of use? Are the shift rails the same?
    j
  3. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    any1? Bueller? Bueller? :confused:
    j
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Does he have any receipts for parts used in the alleged rebuild?
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I doubt you would be able to tell if the bearings were replaced without tearing it down, the only one you will be able to see will be the input bearing (if it has the front and rear yokes installed). Look at all the seals, they better be new, also check the holes where the plugs are that access the shift rail roll pins- should be immaculate. That's all I got.
    Oh yeah, the front input is 31 spline, not interchangable with Chevy. All the guts are identical. HTH
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    thanks for the tips... the 31-spline input may not be compatible with chevy stuff... but it is compatible with a doubler + 31-spline intermediate shaft. :D
    j
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yup, I just sold my Ford 205 input shaft to one of the Amigos for just that purpose. I still have lotsa parts left- want some? :)
  8. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    i have seen my few share of 205s. slopy between input to out put on used. then the 1 fresh reman was nice and tight. just a tiny bit of slop.
