How to tell if a driveshaft is bad??
Discussion in 'The Garage' started by 85mudblazin, Jun 20, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    About a year ago I bought my first blazer and the front driveshaft was not connected but I have it and now that I have gotten into 4 wheeling I want to hook it up but I dont know if it is safe to, what are some things to check?and how would you check such things as splines, u-joints, etc.?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Install it, grab onto the tube, and check for movement by shaking it. If it doesn't move, assume it is fine, and go about your wheeling.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok I dont have any of the straps that connect it to the front 10 b nor do I have the bolts to bolt it to the 208 so where do I get these from??
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Bolts are 7/16-14" by 1-1.25" long grade 8s with lock washers.
    Straps you can get from your local auto parts store.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok so the boltsa that are used to bolt the flange on the driveshaft to the flange on the t-case are 7/16 x 1"? Do you know what kind of u-joint is at the end of the driveshaftf?
    Can I get the straps from napa? and do they come with the bolts?
    Thanks alot.
    /forums/images/graemlins/thumb.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes the straps come with the bolts. The bolts are 5/16-24 but have 7/16" heads instead of the normal 1/2" heads for 5/16" bolts.
    Yes you can get them at Napa. Any place that carries u joints will probably have them.
    That is a 1310 joint at your pinion.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    so can I just tell them I need the straps for a 1310 u-joint?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just tell them you need straps for the front most u joint on a 1985 Chevy K5 Blazer.
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ok Thanks for all the help.
