How to tell if its a NV4500?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79ChevySB, Dec 22, 2001.
  1. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    Do any of you know what year GM started putting NV 4500's into trucks? That and how can you tell the difference between a 4500 and other 5 speeds used.
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The 4500 had a removable bellhousing and the other 5 speed didnt
  3. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    Besides the removable bellhousing is there any part numbers to reference/stamped into the case that I could check? Thanks!
  4. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    The shifter housing/top cover is aluminum too. GM started using the NV4500 in 92 in 3/4 ton and one ton trucks. As far as I know the only other 5 speed used was the Getrag which is an all aluminum one piece tranny. This was found in 88 and up 1/2 tons...
    The NV4500 also has a PTO provision on both sides of the tranny and unless it's been removed should have a warning sticker on one PTO cover telling you to use synthetic gear lube only.
    Here's a link that may help...<a target="_blank" href=http://www.off-road.com/jeep/projects/jeeptherapy5.htm> NV4500</a>
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  5. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    Do you know what transfer cases came behind the 4500? Would it be a NP241? or could you bolt up a NP205? Again thanks for the info guys!
  6. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    The 241 would have been most commonly behind the NV4500. It has a 32 spline output and the generic circular 6 bolt pattern on the rear of the adaptor. I would guess a 32 spline input 205 from a TH400 would bolt right up...
    Rene
  7. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    NV4500 had 241's behind them. A 32 spline input NP208 will bolt up. A 32 spline NP205 with 6 bolt circular adapter will also bolt up.
    87 K5, 427BBC,D60 & 14BFF, NV4500, NP208, TSM disc's,
  8. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    There are two different length 32 spline input gears. I used the short one from a TH400 and machined a notch in the NV4500 tailhousing. It bolted right up. The newer 205s use a long input gear that will need a short spacer between the trans and the Tcase. Oh yeah, you do need the round bolt pattern on the tcase.
  9. 79ChevySB
    Jul 8, 2001
    178
    Denver CO
    If switched my 700R4 to a NV4500 would I have to swap out my 241 or do I have to just swap out the input shaft in the 241? Thanks for all of the help guys!
